Home » Eclipse Projects » Eclipse Scout » Issue after update Eclipse 2024.12(Issue with Eclipse scout SDK)
Issue after update Eclipse 2024.12 [message #1873199] Mon, 09 December 2024 03:47 Go to next message
did any one experienced any issue after last eclipse update ?
I do have this error when creating lookup classes.
An error has occurred. See error log for more details.
Class org.eclipse.jdt.internal.compiler.impl.CompilerOptions does not have member field 'long originalComplianceLevel'
Do any one have a solution for this ?
Kind Regards
Re: Issue after update Eclipse 2024.12 [message #1873202 is a reply to message #1873199] Mon, 09 December 2024 03:49 Go to previous messageGo to next message
Not a real answer yet, but it seems to be the same issue posted in https://www.eclipse.org/forums/index.php/t/1116932/
Re: Issue after update Eclipse 2024.12 [message #1873205 is a reply to message #1873202] Mon, 09 December 2024 03:51 Go to previous message
ok, I switch to the other topic then, the issue seems to be only with lookups and code types, the other are working
Previous Topic:How to remove cancel button to stop transaction
Next Topic:java.lang.NoSuchFieldError exception in Scout SDK core when saving a source file
Current Time: Sat Jul 19 21:09:32 EDT 2025
Powered by FUDForum. Page generated in 0.05718 seconds
