Home » Eclipse Projects » Eclipse Platform » SAXException
SAXException [message #187133] Fri, 30 January 2004 08:02 Go to next message
Originally posted by: philipp.tiedt.de.ibm.com
I tried to implement my own parser subclassing
org.xml.sax.helpers.DefaultHandler. I want to use it in a plugin. However,
when i invoke the parsing i get:
org.xml.sax.SAXException: System property org.xml.sax.driver not specified
My code:
xmlreader = XMLReaderFactory.createXMLReader();
xmlreader.setContentHandler(parser);
xmlreader.parse(source);
Any ideas what could be wrong ?
thx Philipp
Re: SAXException [message #187151 is a reply to message #187133] Fri, 30 January 2004 08:12 Go to previous messageGo to next message
Originally posted by: dani.gueggs.net
What jdk ard you using? The sax parser to use is specified by a system
property. But as you can see in the error message it is not specified in
your case. However you could set the property manually....
see
http://java.sun.com/xml/jaxp/dist/1.0.1/docs/tutorial/index. html
hf,
dani
philipp.tiedt@de.ibm.com wrote:
> My code:
> thx Philipp
Re: SAXException [message #187159 is a reply to message #187151] Fri, 30 January 2004 08:18 Go to previous messageGo to next message
Dani,
I have tried both ibm 1.3.1 and sun 1.4.2
Also I have set the the driver like this System.setProperty("org.xml.sax.driver",
"org.apache.xerces.parsers.SAXParser");
But it wont work.
Re: SAXException [message #187299 is a reply to message #187159] Fri, 30 January 2004 12:01 Go to previous message
Originally posted by: loemming.gmx.net
Okay i have worked out that problem.
Now i get a
java.lang.ClassNotFoundException: org.apache.xerces.parsers.SAXParser
I made my plugin depend on org.apache.xerces .
What else can I do ?
thx
<philipp.tiedt@de.ibm.com> schrieb im Newsbeitrag
news:bvdlim$coe$2@eclipse.org...
> Dani,
> But it wont work.
Previous Topic:JVM Problem
Next Topic:[HOWTO] use Differencer, CompareConfiguration, ICompareInput, IStructureCreator, StructureDiffViewe
Current Time: Sat Jul 19 07:43:24 EDT 2025
Powered by FUDForum. Page generated in 0.03628 seconds
