Home » Language IDEs » ServerTools (WTP) » XML validation will not work in used XMLEditor
XML validation will not work in used XMLEditor [message #186976] Thu, 25 January 2007 09:51 Go to next message
Originally posted by: durchgedreht.gmx.de
when using the XMLEditor as in my last post, the right click "validate"
will not recognize XML structure errors (e.g. <test> </tes> will not be
recognized).
This should not be normal, should it?
Do I have to add anything? I thought it would be the hole XML Editor with
all of its features.
Dennis
Erstellt mit Operas revolutionärem E-Mail-Modul: http://www.opera.com/mail/
Re: XML validation will not work in used XMLEditor [message #186984 is a reply to message #186976] Thu, 25 January 2007 09:53 Go to previous messageGo to next message
For Info: The Crl+Space completion will work, so having written <test>
will show </test> on completion. But no validation? Maybe it is not in the
Problems View anymore???
Dennis
Am 25.01.2007, 15:51 Uhr, schrieb Dennis Meyer <durchgedreht@gmx.de>:
> recognized).
> with all of its features.
> Dennis
Re: XML validation will not work in used XMLEditor [message #187041 is a reply to message #186984] Fri, 26 January 2007 02:34 Go to previous messageGo to next message
You should see red squiggles and X's in the source view. You'll only see
error s in the problems view if your project is configured to 'validate on
save'. If you're working in a web project this should be the default. If
you're working in a simple project you'll need to validate manually or
user the project's preferences to change the validation settings.
Hope that helps
> Dennis
>> Hi,
>> recognized).
>> Thanks,
>> Dennis
Re: XML validation will not work in used XMLEditor [message #187100 is a reply to message #187041] Fri, 26 January 2007 09:07 Go to previous messageGo to next message
Hi Craig,
thanks for that info (is useful as well). But I even don't get that X's =
markers. Maybe I'm wrong using my own extension? I'm using *.jdx and try=
to use the XML contenttype.
INTERESTING SOURCE CODE:
* Creates the xml source editor
void createXMLEditorPage() {
try {
editor =3D new StructuredTextEditor();
int index =3D addPage(editor, getEditorInput());
setPageText(index, editor.getTitle());
} catch (PartInitException e) {
ErrorDialog.openError(
getSite().getShell(),
"Error creating nested text editor",
null,
e.getStatus());
* @see =
org.eclipse.ui.part.MultiPageEditorPart#createSite(org.eclip se.ui.IEdito=
rPart)
protected IEditorSite createSite(IEditorPart page) {
IEditorSite site =3D null;
if (page =3D=3D editor) {
site =3D new MultiPageEditorSite(this, page) {
@SuppressWarnings("restriction")
public String getId() {
// Sets this ID so nested editor is configured for XML source
return ContentTypeIdForXML.ContentTypeID_XML + ".source"; =
//$NON-NLS-1$;
else {
site =3D super.createSite(page);
return site;
FULL SOURCE CODE:
Note that I used the tutorial at:
http://www.eclipse.org/webtools/wst/components/sse/tutorials /multipage-e=
ditor-tutorial.html
package org.jdeluxe.editors;
import java.io.File;
import java.io.FileOutputStream;
import java.io.PrintStream;
import java.io.StringWriter;
import java.text.Collator;
import java.util.ArrayList;
import java.util.Collections;
import java.util.StringTokenizer;
import org.eclipse.core.resources.IMarker;
import org.eclipse.core.resources.IResourceChangeEvent;
import org.eclipse.core.resources.IResourceChangeListener;
import org.eclipse.core.resources.ResourcesPlugin;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.jface.dialogs.ErrorDialog;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.StyledText;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.graphics.Font;
import org.eclipse.swt.graphics.FontData;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.FontDialog;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.IEditorPart;
import org.eclipse.ui.IEditorSite;
import org.eclipse.ui.IFileEditorInput;
import org.eclipse.ui.IWorkbenchPage;
import org.eclipse.ui.PartInitException;
import org.eclipse.ui.ide.IDE;
import org.eclipse.ui.part.FileEditorInput;
import org.eclipse.ui.part.MultiPageEditorPart;
import org.eclipse.ui.part.MultiPageEditorSite;
import org.eclipse.wst.sse.ui.StructuredTextEditor;
import =
org.eclipse.wst.xml.core.internal.provisional.contenttype.Co ntentTypeIdF=
orXML;
* An example showing how to create a multi-page editor.
* This example has 3 pages:
* <ul>
* <li>page 0 contains a nested text editor.
* <li>page 1 allows you to change the font used in page 2
* <li>page 2 shows the words in page 0 in sorted order
* </ul>
public class JdeluxeMultiPageEditor extends MultiPageEditorPart implemen=
ts =
IResourceChangeListener{
/** The text editor used in XML source editor */
private StructuredTextEditor editor;
/** The font chosen in page 1. */
private Font font;
/** The text widget used in page 2. */
private StyledText text;
* Creates a multi-page editor example.
public JdeluxeMultiPageEditor() {
super();
System.out.println("Start test");
getXmlDb();
System.out.println("end test");
ResourcesPlugin.getWorkspace().addResourceChangeListener(thi s);
* Creates page 0 of the multi-page editor,
* which shows the sorted text.
void createPage0() {
Composite composite =3D new Composite(getContainer(), SWT.NONE);
FillLayout layout =3D new FillLayout();
composite.setLayout(layout);
text =3D new StyledText(composite, SWT.H_SCROLL | SWT.V_SCROLL);
text.setEditable(false);
int index =3D addPage(composite);
setPageText(index, "Preview");
try {
null,
e.getStatus());
* Creates page 1 of the multi-page editor,
* which allows you to change the font used in page 2.
void createPage2() {
GridLayout layout =3D new GridLayout();
layout.numColumns =3D 2;
Button fontButton =3D new Button(composite, SWT.NONE);
GridData gd =3D new GridData(GridData.BEGINNING);
gd.horizontalSpan =3D 2;
fontButton.setLayoutData(gd);
fontButton.setText("Change Font...");
fontButton.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent event) {
setFont();
setPageText(index, "Properties");
* Creates the pages of the multi-page editor.
protected void createPages() {
createPage0();
createXMLEditorPage();
createPage2();
* The <code>MultiPageEditorPart</code> implementation of this
* <code>IWorkbenchPart</code> method disposes all nested editors.
* Subclasses may extend.
public void dispose() {
ResourcesPlugin.getWorkspace().removeResourceChangeListener( this);
super.dispose();
* Saves the multi-page editor's document.
public void doSave(IProgressMonitor monitor) {
getEditor(1).doSave(monitor);
* Saves the multi-page editor's document as another file.
* Also updates the text for page 0's tab, and updates this multi-page =
editor's input
* to correspond to the nested editor's.
public void doSaveAs() {
IEditorPart editor =3D getEditor(1);
editor.doSaveAs();
setPageText(1, editor.getTitle());
setInput(editor.getEditorInput());
/* (non-Javadoc)
* Method declared on IEditorPart
public void gotoMarker(IMarker marker) {
setActivePage(1);
IDE.gotoMarker(getEditor(1), marker);
* The <code>MultiPageEditorExample</code> implementation of this metho=
d
* checks that the input is an instance of <code>IFileEditorInput</code=
public void init(IEditorSite site, IEditorInput editorInput)
throws PartInitException {
if (!(editorInput instanceof IFileEditorInput))
throw new PartInitException("Invalid Input: Must be IFileEditorInput"=
super.init(site, editorInput);
/* (non-Javadoc)
* Method declared on IEditorPart.
public boolean isSaveAsAllowed() {
return true;
* Calculates the contents of page 2 when the it is activated.
protected void pageChange(int newPageIndex) {
super.pageChange(newPageIndex);
if (newPageIndex =3D=3D 2) {
sortWords();
* Closes all project files on project close.
public void resourceChanged(final IResourceChangeEvent event){
if(event.getType() =3D=3D IResourceChangeEvent.PRE_CLOSE){
Display.getDefault().asyncExec(new Runnable(){
public void run(){
IWorkbenchPage[] pages =3D getSite().getWorkbenchWindow().getPages(=
for (int i =3D 0; i<pages.length; i++){
if(((FileEditorInput)editor.getEditorInput()).getFile().getP roject=
().equals(event.getResource())){
IEditorPart editorPart =3D =
pages[i].findEditor(editor.getEditorInput());
pages[i].closeEditor(editorPart,true);
* Sets the font related data to be applied to the text in page 2.
void setFont() {
FontDialog fontDialog =3D new FontDialog(getSite().getShell());
fontDialog.setFontList(text.getFont().getFontData());
FontData fontData =3D fontDialog.open();
if (fontData !=3D null) {
if (font !=3D null)
font.dispose();
font =3D new Font(text.getDisplay(), fontData);
text.setFont(font);
* Sorts the words in page 0, and shows them in page 2.
void sortWords() {
String editorText =3D
editor.getDocumentProvider().getDocument(editor.getEditorInp ut()).get=
StringTokenizer tokenizer =3D
new StringTokenizer(editorText, " =
\t\n\r\f!@#\u0024%^&*()-_=3D+`~[]{};:'\",.<>/?|\\");
ArrayList editorWords =3D new ArrayList();
while (tokenizer.hasMoreTokens()) {
editorWords.add(tokenizer.nextToken());
Collections.sort(editorWords, Collator.getInstance());
StringWriter displayText =3D new StringWriter();
for (int i =3D 0; i < editorWords.size(); i++) {
displayText.write(((String) editorWords.get(i)));
displayText.write(System.getProperty("line.separator"));
text.setText(displayText.toString());
* @see =
rPart)
//$NON-NLS-1$;
else {
return site;
private void getXmlDb(){
Re: XML validation will not work in used XMLEditor [message #187165 is a reply to message #186976] Fri, 26 January 2007 21:47 Go to previous messageGo to next message
Dennis Meyer wrote:
> recognized).
The base XML editor will catch those errors. You are sure you are
instantiating the XML Editor and not the Text Editor.
Dave
Re: XML validation will not work in used XMLEditor [message #187258 is a reply to message #186976] Mon, 29 January 2007 08:13 Go to previous message
Dennis Meyer wrote:
> recognized).
No, it's simply bug 86385. The editor handles your custom filename
extension, but the validation framework does not. The problem
markers are generated through the validation framework.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=86385
Nitin Dahyabhai
Structured Source Editor
Previous Topic:Eclipse webinar on the JSF Tools Project
Next Topic:Servlet won't refresh
Current Time: Sun Jul 20 14:16:31 EDT 2025
Powered by FUDForum. Page generated in 0.06208 seconds
