FMI based cosimulation [message #1866855] |
Sun, 09 June 2024 06:29  |
I have been trying to reproduce the FMI tutorial (https://wiki.eclipse.org/Papyrus/UserGuide/ModelExecution) with no success .
I know that papyrus dropped support for FMI (profile and simulation) in papyrus moka so no longer included in the latest update, but it possible to get it using older versions (like moka 2.x.x, 3.x.x and 4.0.0) but the problem is that i always get errors when starting the model execution and i can't see the animation nor the simulation. Besides, the debug configuration gets stuck and i can't even stop the broken simulation until i restart eclipse.
The error i get when starting the debug configuration is "Unhandled event loop exception" and "Uncaught exception during post-commit "( the log file are attached ti this comment).
I tried with many versions of eclipse: neon, oxygen, 201809, 201903 Eclipse Paprys RCP2020, 2023 (see the attached image ) with different papyrus and moka versions. I'm doing this for over a year with no luck (i was previously trying to get ALF to fUML but i gave up).
Can anyone you please suggest a configuration of eclipse/papyrus/moka that will get the FMI working properly
[Updated on: Sun, 09 June 2024 06:53] by Moderator
Re: FMI based cosimulation [message #1866861 is a reply to message #1866858] |
Sun, 09 June 2024 09:44  |
Hi Furkan,
Thank you for your response! and I don't see it as discouragement at all, it actually makes me realize I should have done this months ago - it would have saved me so much time and effort.
I will try to reach out to the developer. I've invested a lot of time and effort, and I'm just a few steps away from achieving my goals.
cheers,
Youcef B.
FUDForum. Page generated in 0.04555 seconds
