Home » Eclipse Projects » Paho » setCleanSession(false) not working with MqttClient/MqttCallbackExtended(Messages lost after recovering from a restart with disable clean session)
setCleanSession(false) not working with MqttClient/MqttCallbackExtended [message #1866450] Thu, 30 May 2024 01:14 Go to next message
I have a setup with mqtt/mosquitto with persistence enabled and verified (using mosquitto_sub -c). Even with QoS=1 and setCleanSession(false) I am loosing messages that is received when my subscription service is stopped.
My expectation is that when I stop and restart after few secs/mins the messages that is received during this time in the server will be available when the subscriber comes back.
This happens when I am using CLI (mosquitto_sub -c..).
Here is the broad codebase. Appreciate any pointers.
public class MqttSubsc implements MqttCallbackExtended{
public MqttSubsc(String mqttUrl, String deviceToken, ..)
        mqttConnectOptions = new MqttConnectOptions();
        mqttConnectOptions.setCleanSession(false);
        mqttConnectOptions.setUserName(deviceToken);
        if (password != null && password.length() > 0)
            mqttConnectOptions.setPassword(password.toCharArray());
        mqttConnectOptions.setAutomaticReconnect(true);
    public void subscribe() throws MqttException{
        this.connect();
    private void connect() throws MqttException
        this.client = new MqttClient(mqttUrl, this.clientid);
        this.client.setCallback(this);
        try
            this.client.connect(this.mqttConnectOptions);
        catch (MqttException mqttex)
            mqttex.printStackTrace();
    public void connectionLost(Throwable cause){...}
    public void connectComplete(boolean arg0, String arg1){
        try{
            this.client.subscribe(this.topic,this.qos);
        }catch (MqttException mqttex)
    public void deliveryComplete(IMqttDeliveryToken token){..}
    public void messageArrived(String topic, MqttMessage message) throws MqttException
        //Handling message here
[Updated on: Thu, 30 May 2024 01:43] by Moderator
Re: setCleanSession(false) not working with MqttClient/MqttCallbackExtended [message #1866513 is a reply to message #1866450] Fri, 31 May 2024 05:54 Go to previous message
Found the problem. I was unsubscribing when the process is shutdown which I should not. If unsubscribed then I would miss all the offline messages even when we subscribe to the topic.
So when setCleanSession is false, DO NOT unsubscribe while disconnecting/closing.
// Add a shutdown hook to unsubscribe and disconnect
            Runtime.getRuntime().addShutdownHook(new Thread(() -> {
                try {
                    LOGGER.info("Please wait..closing subscriber gracefully.");
                    if (this.client.isConnected()) {
                        try {
                            //IMP: If the setCleanSession is false, upon closure of connect, DO NOT unsubscribe
                            //Upon Unsubscribing, we will loose the messages publish during offline.
                            //this.client.unsubscribe(this.topic);
                            this.client.disconnect();
                        }finally {
                            this.client.close();
                            LOGGER.info("Subscriber connection closed successfully.");
                } catch (MqttException e) {
                    e.printStackTrace();
                    LOGGER.error(e);
Previous Topic:One connection of many?
Next Topic:subscribe in connectComplete causing race condition when there are messages
Current Time: Sat Jul 19 23:19:47 EDT 2025
Powered by FUDForum. Page generated in 0.03018 seconds
