Home » Newcomers » Newcomers » Can't use SWT in eclipse(get a security exception when using external SWT jar)
Can't use SWT in eclipse [message #1865400] Thu, 02 May 2024 10:19 Go to next message
I have downloaded the SWT jar from the eclipse website and added it to:
java build path -> libraries
in the properties to the project
i can import classes from the jar but when i try to run it i get this:
Exception in thread "main" java.lang.SecurityException: Invalid signature file digest for Manifest main attributes
at java.base/sun.security.util.SignatureFileVerifier.processImpl(SignatureFileVerifier.java:347)
at java.base/sun.security.util.SignatureFileVerifier.process(SignatureFileVerifier.java:289)
at java.base/java.util.jar.JarVerifier.processEntry(JarVerifier.java:283)
at java.base/java.util.jar.JarVerifier.update(JarVerifier.java:239)
at java.base/java.util.jar.JarFile.initializeVerifier(JarFile.java:761)
at java.base/java.util.jar.JarFile.getInputStream(JarFile.java:849)
at java.base/jdk.internal.module.ModuleReferences$JarModuleReader.implOpen(ModuleReferences.java:265)
at java.base/jdk.internal.module.ModuleReferences$SafeCloseModuleReader.open(ModuleReferences.java:180)
at java.base/java.lang.module.ModuleReader.read(ModuleReader.java:174)
at java.base/jdk.internal.loader.BuiltinClassLoader.defineClass(BuiltinClassLoader.java:809)
at java.base/jdk.internal.loader.BuiltinClassLoader.findClassInModuleOrNull(BuiltinClassLoader.java:741)
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClassOrNull(BuiltinClassLoader.java:665)
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:639)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:188)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:525)
at bla/bla.bla.main(bla.java:14)
can someone help? thanks
im on xubuntu 22
Re: Can't use SWT in eclipse [message #1865475 is a reply to message #1865400] Sat, 04 May 2024 01:32 Go to previous messageGo to next message
You can ask here:
https://github.com/eclipse-platform/eclipse.platform.swt/discussions
But folks will want to know, exactly which version of SWT did you get and from where exactly did you get it, as well as which version of Java you are using.
Re: Can't use SWT in eclipse [message #1867098 is a reply to message #1865400] Fri, 14 June 2024 10:03 Go to previous message
TryThis:
https://www.eclipse.org/swt/eclipse.php
Previous Topic:Upgrade to 2024-06 unable to read workspace
Next Topic:About the required specifications of Eclipse IDE
Current Time: Sun Jul 20 12:15:11 EDT 2025
Powered by FUDForum. Page generated in 0.09655 seconds
