Home » Language IDEs » PHP Development Tools (PDT) » How do I disable auto-completion pop-up
How do I disable auto-completion pop-up [message #1864532] Thu, 21 March 2024 17:17 Go to next message
I'm trying to disable automatic code-completition pop-up. I want it to appear only when I press CTRL-Space.
I've tried to disable all options in PHP->Editor->Content Assist but it still shows up.
Searching preferences I could only find relevant option in this place. Other Content Assist pages are for CSS, HTML or XML.
How do I disable it ?
I'm using PDT to develop in Angular/Typescript/Javascript.
This is relevant because it interferes with AI code suggestions like Codeium.
Please inform if this issue should be addressed to Wild Web Developer project
[Updated on: Thu, 21 March 2024 18:06] by Moderator
Re: How do I disable auto-completion pop-up [message #1865049 is a reply to message #1864532] Thu, 25 April 2024 04:06 Go to previous message
Here's what you can try:
PDT Settings Might Be Limited:
Unfortunately, PDT doesn't seem to have separate settings for Javascript/Typescript like other languages. The options you found for PHP might not apply.
Try These Workarounds:
Search for "Autopopup": While less likely, search PDT settings for keywords like "Autopopup code completion" or similar. It might be a global option.
Keyboard Shortcuts:
Disable all suggestions: Try Ctrl+Shift+Space (might temporarily disable AI suggestions too).
Trigger suggestions manually: Use Ctrl+Space when you want completions.
Wild Web Developer Might Not Be the Answer:
Since PDT's settings seem limited, contacting the Wild Web Developer project might not be the best course of action.
Alternatives:
Consider PDT Support: If the workarounds don't work, contact PDT support to see if there's a hidden setting or a known issue.
Explore Other IDEs: If disabling automatic suggestions is crucial, investigate other IDEs that offer more granular control over code completion behavior.
Hopefully, these suggestions help you manage code completion in PDT!
Previous Topic:Quick Type Hierarchy not working anymore
Next Topic:New PHP Project from Composer Package can't see package version
Current Time: Sun Jul 20 12:30:48 EDT 2025
Powered by FUDForum. Page generated in 0.04087 seconds
