MOM marshaller question [message #1864046] |
Wed, 13 March 2024 07:15  |
Hello all,
I am currently testing how to use MOM and it works fine so far when using the default ObjectMapper. But when trying to configure a different mapper like the JsonMapper I find that the ObjectMapper is still being used.
default.properties:
scout.mom.cluster.environment[scout.mom.jms.clientId]=Test
scout.mom.cluster.environment[scout.mom.name]=Scout Cluster MOM
scout.mom.cluster.environment[scout.mom.connectionfactory.name]=ClusterMom
scout.mom.cluster.environment[java.naming.factory.initial]=org.apache.activemq.jndi.ActiveMQInitialContextFactory
scout.mom.cluster.environment[java.naming.provider.url]=tcp://localhost:61616?jms.useAsyncSend=true
scout.mom.cluster.environment[connectionFactoryNames]=ClusterMom
scout.mom.cluster.environment[java.naming.security.principal]=USERNAME
scout.mom.cluster.environment[java.naming.security.credentials]=PASSWORD
scout.mom.cluster.implementor=org.eclipse.scout.rt.mom.jms.JmsMomImplementor
scout.mom.marshaller=org.eclipse.scout.rt.mom.api.marshaller.JsonMarshaller
At startup Eclipse Scout shows the following information:
Scout Cluster MOM configuration: {scout.mom.name=Scout Cluster MOM, java.naming.security.principal=USERNAME, java.naming.factory.initial=org.apache.activemq.jndi.ActiveMQInitialContextFactory, scout.mom.connectionfactory.name=ClusterMom, java.naming.provider.url=tcp://localhost:61616?jms.useAsyncSend=true, connectionFactoryNames=ClusterMom, java.naming.security.credentials=PASSWORD, scout.mom.jms.clientId=Test, scout.mom.marshaller=org.eclipse.scout.rt.mom.api.marshaller.ObjectMarshaller@63c5542f}
ObjectMarshaller is still being used which I can also confirm from the subscriber side having a look at the message received from my connected test service.
Taking a look at the ClusterMom implementation I can see that ObjectMarshaller is set as the DefaultMarshaller there.
What am I missing? Any ideas or pointers for me?
Best regards
Stefan
[Updated on: Wed, 13 March 2024 07:17] by Moderator
FUDForum. Page generated in 0.03172 seconds
