Home » Language IDEs » ServerTools (WTP) » can't access tomcat manager application when starting tomcat internally
can't access tomcat manager application when starting tomcat internally [message #186322] Tue, 16 January 2007 14:10 Go to next message
versions
eclipse: 3.2
tomcat: 5.5.20
wtp: 1.5
If I start tomcat from within eclipse via the servers windows, I get 404
errors if I try to access any of the urls:
http://localhost:8080/
http://localhost:8080/manager/html
http://localhost:8080/admin
If I start tomcat from the command line with startup.bat, the same urls
give me the expected results, namely the welcome, manager, and admin
pages, respectively.
Is there a way to get access to these pages if tomcat is started from
within eclipse?
Chuck
Re: can't access tomcat manager application when starting tomcat internally [message #186374 is a reply to message #186322] Wed, 17 January 2007 08:14 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Chuck,
WTP is using it's custom config files for starting and stopping tomcat, and the
webapp is run from ".metadata\.plugins\org.eclipse.wst.server.core\tmp0". So the
eclipse tomcat uses all the tomcat binaries, but the webapps from your tomcat
installation are ignored.
Even the config is not used, WTP brings it's own tomcat configuration in a
directory "Servers" in your workspace.
Take a look at the server settings (in the "servers view", select your Tomcat,
rightlick, "Open"). There is an option "Run modules directly from the
workspace". If you switch it off it should use your full tomcat installation (I
hope, never used it).
Best regards
Wolfgang
Chuck wrote:
> versions
> eclipse: 3.2
> tomcat: 5.5.20
> wtp: 1.5
> within eclipse?
> Chuck
Re: can't access tomcat manager application when starting tomcat internally [message #186381 is a reply to message #186374] Wed, 17 January 2007 08:50 Go to previous messageGo to next message
To expand a little on what Wolfgang said, the default is to create a
Tomcat server instance separate from your installation. You can also
double-click the server in the Servers view to open the server editor
where you find the "Run modules directly..." option. To see where this
separate instance lives, click on the "Open launch configuration" link
in the server editor. In the launch configuration Properties dialog that
appears, switch to the Arguments tab and view the location by examining
the setting for catalina.base in the "VM arguments" field.
This separate instance gets an "empty" default/ROOT webapp. Since
directory listings are disabled by default in Tomcat 5.5.20, your first
URL results in a 404 error. The others give 404 errors because the
associated webapp isn't present by default in the new instance.
One important thing to note about unchecking the "Run modules
directly..." option is that the configuration files found under the
Servers project in your workspace become the "masters" for these files.
With the option unchecked, they will overwrite those in your Tomcat
installation each time the Tomcat server is started within Eclipse. Any
changes saved using the manager or admin webapps will be lost the next
time the Tomcat server is started in Eclipse.
Larry
Wolfgang Knauf wrote:
> Hi Chuck,
> and the webapp is run from
> ".metadata\.plugins\org.eclipse.wst.server.core\tmp0". So the eclipse
> a directory "Servers" in your workspace.
> Tomcat, rightlick, "Open"). There is an option "Run modules directly
> from the workspace". If you switch it off it should use your full tomcat
> installation (I hope, never used it).
> Best regards
> Wolfgang
> Chuck wrote:
>> versions
>> eclipse: 3.2
>> tomcat: 5.5.20
>> wtp: 1.5
>> 404 errors if I try to access any of the urls:
>> urls give me the expected results, namely the welcome, manager, and
>> admin pages, respectively.
>> within eclipse?
>> Thanks,
>> Chuck
Re: can't access tomcat manager application when starting tomcat internally [message #186416 is a reply to message #186381] Wed, 17 January 2007 13:22 Go to previous message
Wolfgang, Larry,
Thanks for your help. I think I have it sorted out now.
Chuck
> Cheers,
> Larry
>> Hi Chuck,
>> ".metadata.pluginsorg.eclipse.wst.server.coretmp0". So the eclipse
>> Best regards
>> Wolfgang
>> Chuck wrote:
>>> versions
>>> eclipse: 3.2
>>> tomcat: 5.5.20
>>> wtp: 1.5
>>> within eclipse?
>>> Thanks,
>>> Chuck
Previous Topic:can't run a jsp page
Next Topic:API-only way to create dynamic web project using facets
Current Time: Sun Jul 20 13:22:14 EDT 2025
Powered by FUDForum. Page generated in 0.03956 seconds
