Home » Language IDEs » ServerTools (WTP) » turning off tomcat logs
turning off tomcat logs [message #186006] Thu, 11 January 2007 11:09 Go to next message
Originally posted by: andrea.cossu.gruppoatlantis.com
How can i turn off the logging in eclipse embedded tomcat?
tnks
andrea
Re: turning off tomcat logs [message #186137 is a reply to message #186006] Fri, 12 January 2007 15:00 Go to previous message
I assume by logging you mean output to the Console. If you want to send
the console output to the bit bucket, double-click on the server in the
Servers view. In the server editor that appears, click the "Open launch
configuration" link. In the launch configuration Properties dialog,
switch to the Common tab and uncheck "Allocate Console".
If the problem is that the Console view keeps popping to the front at
annoying times, try Window -> Properties. In the tree on the left,
select Run/Debug and Console. Uncheck "Show when program writes to
standard out" and possibly "Show when program writes to standard error".
Larry
> tnks
> andrea
Previous Topic:Future of the WTP version of the SQL model
Next Topic:applet dependecy
Current Time: Sun Jul 20 06:24:48 EDT 2025
Powered by FUDForum. Page generated in 0.02876 seconds
