Home » Eclipse Projects » Oomph » Specifying restrictions on a P2 director(Syntax for restriction)
Specifying restrictions on a P2 director [message #1860912] Fri, 08 September 2023 08:26 Go to next message
When using the oomph setup editor, if I click on the restrictions property on a P2 director element I am provided with a list of choices. Is it possible to use a boolean expression under feature. Here are two examples and I would like if you could comment on both as to whether they are possible:
Feature not equal to product x, version y
Feature version > y for product x
Thanks for the pointer.
Re: Specifying restrictions on a P2 director [message #1860925 is a reply to message #1860912] Sat, 09 September 2023 03:50 Go to previous message
A restriction is just a list of scopes:
 EList<Scope> getRestrictions();
and is just used when gathering tasks to skip a task when all the given scopes are not "selected".
https://github.com/eclipse-oomph/oomph/blob/d9218b44aa6d97dfc08d5fae65717ebbaf8fddfb/plugins/org.eclipse.oomph.setup.core/src/org/eclipse/oomph/setup/internal/core/SetupTaskPerformer.java#L1717-L1732
There are a bunch of predefined variables that could be used in filters:
https://wiki.eclipse.org/Eclipse_Oomph_Authoring#Predefined_Variables
But the version name (scope.product.version.name) is not generally a number that you can use for order comparison though...
Previous Topic:Targlet requirement filter with oomph variable
Next Topic:Calling a script within a oomph setup
Current Time: Sun Jul 20 18:50:53 EDT 2025
Powered by FUDForum. Page generated in 0.05054 seconds
