Failed to evaluate 'OclElement::allInstances() : Set(OclSelf)' for ... [message #1860726] |
Tue, 29 August 2023 13:32  |
Context:
I'm testing some OCL defined in a plugin in my first Eclipse by launching a second Eclipse. I then use OCL->Load Document->Browse File System to load the initial OCL file containing the highest level 'def's and 'inv's. This file then loads other files referenced via : "include 'platform:/plugin/..." . Some of those included OCL files include others. In addition, these files contain references to the relevant ecore files via "import 'platform/plugin/..." . There are 4 ecore metamodels generated from XText, with each building on the next ('with' in XText terminology). See screenshot #1 (10.14.22 AM)
I can see the results of loading these files in the ValidityView. I can evaluate the invariants and many of them pass or provide only warnings against my test model, as expected. Some of the invariants that pass call 'allInstances()`. See Screenshot #2: (10.16.24 AM)
Problem:
I'm getting some errors that, when I mouse over the failure in the ValidityView, display as a StackOverflowError. See screenshot #3 (10.19.16 AM). When I attempt to debug these, the failure occurs in a call to `allInstances()`, whch is typically the first thing done (so there isn't a recursive loop or any other obvious cause of a StackOverflowError AFAIK). The models I'm using aren't that large - I have < 100 instances of each type. If this is really a Stack Overflow problem, then it seems like I should set my JVM parameters better when I launch the second Eclipse. Currently, they are:
-Dorg.eclipse.swt.graphics.Resource.reportNonDisposed=true -Xms4G -Xmx8G -XX:+UseStringDeduplication
FWIW, I'm running on a 16Gb M1 Macbook Pro. See screenshot #4 (10.26.49 AM)
I have not seen any recommendation in the OCL doc on JVM memory settings. Is there any? Is it possible that the problem is not the size of my model but the number of OCL 'def's and 'inv's I've got? Or is there something about how 'allInstances()' works that I need to be aware of? I think all OCL calls to 'allInstances()' are in the same plugin as the ecore file containing the metamodel that particular 'allInstances()' needs. Or is it that the type on which `allInstances()` is called must also be the `context` type?
Sample Stacktrace:
Diagnostic ERROR source=org.eclipse.ocl.examples.debug.evaluation code=120 Failed to evaluate 'OclElement::allInstances() : Set(OclSelf)' for 'ConceptualEntity' and 'uddl::ConceptualEntity.allInstances()' data=[java.lang.UnsupportedOperationException]
[Java cause:]
at org.eclipse.ocl.examples.debug.evaluator.OCLVMModelManager.get(OCLVMModelManager.java:54)
at org.eclipse.ocl.pivot.library.classifier.ClassifierAllInstancesOperation.evaluate(ClassifierAllInstancesOperation.java:63)
at org.eclipse.ocl.pivot.library.classifier.ClassifierAllInstancesOperation.evaluate(ClassifierAllInstancesOperation.java:1)
at org.eclipse.ocl.pivot.library.AbstractUnaryOperation.dispatch(AbstractUnaryOperation.java:39)
at org.eclipse.ocl.pivot.internal.evaluation.BasicEvaluationVisitor.visitOperationCallExp(BasicEvaluationVisitor.java:725)
at org.eclipse.ocl.pivot.internal.OperationCallExpImpl.accept(OperationCallExpImpl.java:572)
at org.eclipse.ocl.examples.debug.vm.evaluator.AbstractVMEvaluationStepper.visiting(AbstractVMEvaluationStepper.java:449)
at org.eclipse.ocl.examples.debug.evaluator.OCLVMEvaluationVisitor.visiting(OCLVMEvaluationVisitor.java:235)
at org.eclipse.ocl.pivot.util.AbstractMergedVisitor.visitOperationCallExp(AbstractMergedVisitor.java:379)
at org.eclipse.ocl.pivot.internal.evaluation.BasicEvaluationVisitor.visitIteratorExp(BasicEvaluationVisitor.java:473)
at org.eclipse.ocl.pivot.internal.IteratorExpImpl.accept(IteratorExpImpl.java:2046)
at org.eclipse.ocl.pivot.util.AbstractMergedVisitor.visitIteratorExp(AbstractMergedVisitor.java:269)
at org.eclipse.ocl.pivot.internal.evaluation.BasicEvaluationVisitor.visitOperationCallExp(BasicEvaluationVisitor.java:654)
at org.eclipse.ocl.pivot.internal.evaluation.BasicEvaluationVisitor.evaluate(BasicEvaluationVisitor.java:142)
at org.eclipse.ocl.examples.debug.evaluator.OCLVMEvaluationVisitor.evaluate(OCLVMEvaluationVisitor.java:66)
at org.eclipse.ocl.pivot.internal.evaluation.AbstractExecutor.evaluate(AbstractExecutor.java:206)
at org.eclipse.ocl.pivot.internal.library.ConstrainedOperation.basicEvaluate(ConstrainedOperation.java:60)
at org.eclipse.ocl.pivot.internal.evaluation.EvaluationCache.getCachedEvaluationResult(EvaluationCache.java:133)
at org.eclipse.ocl.pivot.internal.evaluation.AbstractExecutor.getCachedEvaluationResult(AbstractExecutor.java:219)
at org.eclipse.ocl.pivot.library.AbstractOperation.evaluate(AbstractOperation.java:82)
at org.eclipse.ocl.pivot.internal.library.ConstrainedOperation.dispatch(ConstrainedOperation.java:81)
at org.eclipse.ocl.pivot.internal.evaluation.BasicEvaluationVisitor.visitVariable(BasicEvaluationVisitor.java:903)
at org.eclipse.ocl.pivot.util.AbstractExtendingVisitor.visitLetVariable(AbstractExtendingVisitor.java:302)
at org.eclipse.ocl.pivot.internal.LetVariableImpl.accept(LetVariableImpl.java:334)
at org.eclipse.ocl.pivot.util.AbstractMergedVisitor.visitLetVariable(AbstractMergedVisitor.java:294)
at org.eclipse.ocl.pivot.internal.evaluation.BasicEvaluationVisitor.visitLetExp(BasicEvaluationVisitor.java:573)
at org.eclipse.ocl.pivot.internal.LetExpImpl.accept(LetExpImpl.java:580)
at org.eclipse.ocl.pivot.util.AbstractMergedVisitor.visitLetExp(AbstractMergedVisitor.java:289)
at org.eclipse.ocl.pivot.internal.library.ConstrainedOperation.dispatch(ConstrainedOperation.java:79)
at org.eclipse.ocl.pivot.library.logical.BooleanImpliesOperation.dispatch(BooleanImpliesOperation.java:42)
at org.eclipse.ocl.pivot.internal.evaluation.BasicEvaluationVisitor.visitTupleLiteralPart(BasicEvaluationVisitor.java:839)
at org.eclipse.ocl.pivot.internal.TupleLiteralPartImpl.accept(TupleLiteralPartImpl.java:560)
at org.eclipse.ocl.pivot.util.AbstractMergedVisitor.visitTupleLiteralPart(AbstractMergedVisitor.java:589)
at org.eclipse.ocl.pivot.internal.evaluation.BasicEvaluationVisitor.visitTupleLiteralExp(BasicEvaluationVisitor.java:831)
at org.eclipse.ocl.pivot.internal.TupleLiteralExpImpl.accept(TupleLiteralExpImpl.java:287)
at org.eclipse.ocl.pivot.util.AbstractMergedVisitor.visitTupleLiteralExp(AbstractMergedVisitor.java:584)
at org.eclipse.ocl.pivot.internal.evaluation.BasicEvaluationVisitor.visitPropertyCallExp(BasicEvaluationVisitor.java:776)
at org.eclipse.ocl.pivot.internal.PropertyCallExpImpl.accept(PropertyCallExpImpl.java:445)
at org.eclipse.ocl.pivot.util.AbstractMergedVisitor.visitPropertyCallExp(AbstractMergedVisitor.java:449)
at org.eclipse.ocl.pivot.internal.evaluation.BasicEvaluationVisitor.safeVisit(BasicEvaluationVisitor.java:160)
at org.eclipse.ocl.pivot.internal.evaluation.BasicEvaluationVisitor.visitExpressionInOCL(BasicEvaluationVisitor.java:316)
at org.eclipse.ocl.pivot.internal.ExpressionInOCLImpl.accept(ExpressionInOCLImpl.java:535)
at org.eclipse.ocl.pivot.util.AbstractMergedVisitor.visitExpressionInOCL(AbstractMergedVisitor.java:204)
at org.eclipse.ocl.examples.debug.evaluator.OCLVMExecutor.execute(OCLVMExecutor.java:112)
at org.eclipse.ocl.examples.debug.vm.launching.InternalDebuggableExecutor.doExecute(InternalDebuggableExecutor.java:164)
at org.eclipse.ocl.examples.debug.vm.launching.InternalDebuggableExecutor.execute(InternalDebuggableExecutor.java:269)
at org.eclipse.ocl.examples.debug.vm.launching.DebuggableRunner.execute(DebuggableRunner.java:118)
at org.eclipse.ocl.examples.debug.vm.launching.DebuggableRunner$2.execute(DebuggableRunner.java:85)
at org.eclipse.ocl.examples.debug.vm.VMVirtualMachine.execute(VMVirtualMachine.java:164)
at org.eclipse.ocl.examples.debug.vm.VMVirtualMachine.access$14(VMVirtualMachine.java:161)
at org.eclipse.ocl.examples.debug.vm.VMVirtualMachine$1.run(VMVirtualMachine.java:221)
at java.base/java.lang.Thread.run(Thread.java:833)
[Updated on: Tue, 29 August 2023 16:18] by Moderator
FUDForum. Page generated in 0.04884 seconds
