Home » Modeling » EMF » AbstractCDOIDLong is no longer available
AbstractCDOIDLong is no longer available [message #1860715] Mon, 28 August 2023 19:55 Go to next message
Hi!
I'm migrating from CDO 3.0.1 to CDO 4.10.0 (the reason 4.10.0 has been chosen is Java 8 support).
In CDO 3.0.1 I used AbstractCDOIDLong to convert CDOID to long value
query.setParameter( "deviceId", ( (AbstractCDOIDLong) hardwareDevice.cdoID() ).getLongValue() );
However, there is no AbstractCDOIDLong in CDO 4.10.0. My question is how to convert CDO ID to the type I need? Do I need to change my model if AbstractCDOIDLong /AbstractCDOIDInt are no longer available?
Re: AbstractCDOIDLong is no longer available [message #1860716 is a reply to message #1860715] Mon, 28 August 2023 23:54 Go to previous messageGo to next message
Sorry, I have found an appropriate replacement for this class - CDOIDObjectLongImpl
Re: AbstractCDOIDLong is no longer available [message #1860717 is a reply to message #1860716] Tue, 29 August 2023 01:02 Go to previous message
It's much easier to upgrade the dependencies of your application when you use the public APIs of those dependencies. In this case you should use
long value = CDOIDUtil.getLong(id);
These public methods are often easy to find by opening the call hierarchy on the internal method that you've already found.
Previous Topic:How can you change properties of attributes at runtime?
Next Topic:How to use tycho plugin
Current Time: Sun Jul 20 09:31:25 EDT 2025
Powered by FUDForum. Page generated in 0.04247 seconds
