Home » Modeling » Papyrus » XSD import(Is it possible to import XSD structures to Papyrus? )
XSD import [message #1860442] Sat, 05 August 2023 10:41 Go to next message
Hi all,
I have a question:
Is there a possibility (e.g. plugin) to import XSD structures into the Papyrus CASE tool?
EA supports it, although I'm not entirely sure if it's doing it correctly.
https://sparxsystems.com/enterprise_architect_user_guide/16.0/modeling_domains/import_xsd.html
Thanks for the answers
Re: XSD import [message #1860494 is a reply to message #1860442] Wed, 09 August 2023 21:10 Go to previous messageGo to next message
Hi, Ilja,
I don't know whether there's any easier path, but you should be able to import from XSD into a UML model using the XSD file as the source in the New UML (or New UML2?) model file wizard. Then you can create a Papyrus model from their UML file and initialize a class diagram from it.
I haven't any clear details beyond that, sorry.
HTH,
Christian
Re: XSD import [message #1860497 is a reply to message #1860494] Thu, 10 August 2023 03:02 Go to previous message
If direct XSD2UML fails, you may have more success with XSD2Ecore, which is used more often. Perhaps tidy up the Ecore to exploit the benefits of modelling, then do Ecore2UML.
Previous Topic:How to import Classes and ownedAttributes with Comments
Next Topic:Overriding the ModelExplorer
Current Time: Sun Jul 20 18:45:51 EDT 2025
Powered by FUDForum. Page generated in 0.04116 seconds
