Home » Language IDEs » Java Development Tools (JDT) » Upgrading to Eclipse SDK 4.16(build fails)
Upgrading to Eclipse SDK 4.16 [message #1859289] Fri, 26 May 2023 13:12 Go to next message
I have upgraded Eclipse SDK from 4.2.2 to 4.16 in my existing project. Java 8.0.7.20 is used as Java compiler.
I strongly feel that issue with plugin version conflict. I tried many things. Can you look at the error log and suggest me something.
Thanks much in advance.
I am getting following build failed exceptions->
build-embedded:
[exec] !SESSION 2023-05-26 22:16:35.142 -----------------------------------------------
[exec] eclipse.buildId=4.16.0.I20200604-0540
[exec] java.version=1.8.0_372
[exec] java.vendor=Red Hat, Inc.
[exec] BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
[exec] Framework arguments: -application org.eclipse.ant.core.antRunner -buildfile /home/sdi/SDI/tools_git/eclipse/eclipse_runtime/4.16/eclipse/plugins/org.eclipse.pde.build_3.10.800.v20200410-1419/scripts/build.xml -Dbuilder=/home/sdi/SDI/export/osgi/builder -DtopLevelElementType=feature -DtopLevelElementId=com.ibm.di.feature -DrunPackager=false -DarchivePrefix=eclipse -Dconfigs=*, *, * -DbuildDirectory=/home/sdi/SDI/export/osgi/builder -DbuildType=N -DbuildId=build -DbuildLabel=com.ibm.di -DforceContextQualifier=0 -DoutputUpdateJars=true -DbaseLocation=/home/sdi/SDI/export/osgi/runtime -Dbaseos=win32 -Dbasews=win32 -Dbasearch=x86 -DfilteredDependencyCheck=false -Dresolution.devMode=true -DskipBase=true -DskipMaps=true -DskipFetch=true -DlogExtension=.log -DjavacDebugInfo=true -DjavacFailOnError=true -DjavacVerbose=false -DjavacSource=1.8 -DjavacTarget=1.8
[exec] Command-line arguments: -application org.eclipse.ant.core.antRunner -buildfile /home/sdi/SDI/tools_git/eclipse/eclipse_runtime/4.16/eclipse/plugins/org.eclipse.pde.build_3.10.800.v20200410-1419/scripts/build.xml -Dbuilder=/home/sdi/SDI/export/osgi/builder -consoleLog -DtopLevelElementType=feature -DtopLevelElementId=com.ibm.di.feature -DrunPackager=false -DarchivePrefix=eclipse -Dconfigs=*, *, * -DbuildDirectory=/home/sdi/SDI/export/osgi/builder -DbuildType=N -DbuildId=build -DbuildLabel=com.ibm.di -DforceContextQualifier=0 -DoutputUpdateJars=true -DbaseLocation=/home/sdi/SDI/export/osgi/runtime -Dbaseos=win32 -Dbasews=win32 -Dbasearch=x86 -DfilteredDependencyCheck=false -Dresolution.devMode=true -DskipBase=true -DskipMaps=true -DskipFetch=true -DlogExtension=.log -DjavacDebugInfo=true -DjavacFailOnError=true -DjavacVerbose=false -DjavacSource=1.8 -DjavacTarget=1.8
[exec] !ENTRY org.eclipse.emf.codegen 4 0 2023-05-26 22:16:35.822
[exec] !MESSAGE FrameworkEvent ERROR
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.codegen [204]
[exec] Unresolved requirement: Require-Bundle: org.eclipse.jdt.core; bundle-version="[3.5.0,4.0.0)"
[exec] at org.eclipse.osgi.container.Module.start(Module.java:463)
[exec] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845)
[exec] at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)
[exec] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838)
[exec] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1779)
[exec] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743)
[exec] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665)
[exec] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
[exec] at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
[exec] at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)
[exec] !ENTRY org.eclipse.emf.codegen.ecore 4 0 2023-05-26 22:16:35.826
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.codegen.ecore [205]
[exec] !ENTRY org.eclipse.emf.ecore.sdo.editor 4 0 2023-05-26 22:16:35.826
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.ecore.sdo.editor [219]
[exec] Unresolved requirement: Require-Bundle: org.eclipse.emf.codegen.ecore; bundle-version="[2.2.0,3.0.0)"
[exec] -> Bundle-SymbolicName: org.eclipse.emf.codegen.ecore; bundle-version="2.9.1.v20130902-0605"; singleton:="true"
[exec] org.eclipse.emf.codegen.ecore [205]
[exec] !ENTRY org.eclipse.emf.examples.generator.validator 4 0 2023-05-26 22:16:35.827
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.examples.generator.validator [227]
[exec] Unresolved requirement: Require-Bundle: org.eclipse.emf.codegen.ecore; bundle-version="[2.9.0,3.0.0)"
[exec] !ENTRY org.eclipse.emf.java 4 0 2023-05-26 22:16:35.828
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.java [245]
[exec] Unresolved requirement: Require-Bundle: org.eclipse.jdt.core; bundle-version="[3.5.0,4.0.0)"; visibility:="reexport"
[exec] !ENTRY org.eclipse.emf.java.edit 4 0 2023-05-26 22:16:35.828
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.java.edit [246]
[exec] Unresolved requirement: Require-Bundle: org.eclipse.emf.java; bundle-version="[2.5.0,3.0.0)"; visibility:="reexport"
[exec] -> Bundle-SymbolicName: org.eclipse.emf.java; bundle-version="2.5.0.v20130902-0605"; singleton:="true"
[exec] org.eclipse.emf.java [245]
[exec] !ENTRY org.eclipse.emf.ant 4 0 2023-05-26 22:16:35.831
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.ant [668]
[exec] Unresolved requirement: Require-Bundle: org.eclipse.emf.codegen; bundle-version="[2.9.0,3.0.0)"
[exec] -> Bundle-SymbolicName: org.eclipse.emf.codegen; bundle-version="2.9.0.v20130902-0605"; singleton:="true"
[exec] org.eclipse.emf.codegen [204]
[exec] Unresolved requirement: Require-Bundle: org.eclipse.emf.codegen.ecore; bundle-version="[2.9.0,3.0.0)"; resolution:="optional"
[exec] !ENTRY org.eclipse.emf.converter 4 0 2023-05-26 22:16:35.831
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.converter [669]
[exec] Unresolved requirement: Require-Bundle: org.eclipse.emf.codegen.ecore.ui; bundle-version="[2.9.0,3.0.0)"; resolution:="optional"
[exec] Unresolved requirement: Require-Bundle: org.eclipse.emf.codegen.ecore; bundle-version="[2.9.0,3.0.0)"; visibility:="reexport"
[exec] !ENTRY org.eclipse.emf.exporter 4 0 2023-05-26 22:16:35.834
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.exporter [670]
[exec] Unresolved requirement: Require-Bundle: org.eclipse.emf.converter; bundle-version="[2.6.0,3.0.0)"; visibility:="reexport"
[exec] -> Bundle-SymbolicName: org.eclipse.emf.converter; bundle-version="2.6.0.v20130902-0605"; singleton:="true"
[exec] org.eclipse.emf.converter [669]
[exec] !ENTRY org.eclipse.emf.exporter.html 4 0 2023-05-26 22:16:35.844
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.exporter.html [671]
[exec] Unresolved requirement: Require-Bundle: org.eclipse.emf.exporter; bundle-version="[2.7.0,3.0.0)"
[exec] -> Bundle-SymbolicName: org.eclipse.emf.exporter; bundle-version="2.7.0.v20130902-0605"; singleton:="true"
[exec] org.eclipse.emf.exporter [670]
[exec] !ENTRY org.eclipse.emf.importer 4 0 2023-05-26 22:16:35.845
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.importer [672]
[exec] !ENTRY org.eclipse.emf.importer.java 4 0 2023-05-26 22:16:35.845
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.importer.java [673]
[exec] !ENTRY org.eclipse.emf.importer.rose 4 0 2023-05-26 22:16:35.846
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.importer.rose [674]
[exec] Unresolved requirement: Require-Bundle: org.eclipse.emf.importer; bundle-version="[2.8.0,3.0.0)"
[exec] -> Bundle-SymbolicName: org.eclipse.emf.importer; bundle-version="2.8.0.v20130902-0605"; singleton:="true"
[exec] org.eclipse.emf.importer [672]
[exec] Unresolved requirement: Require-Bundle: org.eclipse.emf.ant; bundle-version="[2.8.0,3.0.0)"; resolution:="optional"
[exec] -> Bundle-SymbolicName: org.eclipse.emf.ant; bundle-version="2.8.0.v20130902-0605"; singleton:="true"
[exec] org.eclipse.emf.ant [668]
[exec] !ENTRY org.eclipse.xsd.ecore.exporter 4 0 2023-05-26 22:16:35.846
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.xsd.ecore.exporter [675]
[exec] !ENTRY org.eclipse.xsd.ecore.importer 4 0 2023-05-26 22:16:35.848
[exec] !STACK 0
[exec] org.osgi.framework.BundleException: Could not resolve module: org.eclipse.xsd.ecore.importer [676]
[exec] Buildfile: /home/sdi/SDI/tools_git/eclipse/eclipse_runtime/4.16/eclipse/plugins/org.eclipse.pde.build_3.10.800.v20200410-1419/scripts/build.xml
[exec] main:
[exec] preBuild:
[exec] preSetup:
[exec] [echo] Building plugins: com.ibm.di.api,com.ibm.di.api.bind,com.ibm.di.api.connection,com.ibm.di.api.impl,com.ibm.di.api.rest,com.ibm.di.bundle,com.ibm.di.component,com.ibm.di.config,com.ibm.di.config.bind,com.ibm.di.connector.taddm,com.ibm.di.http.jetty.listener,com.ibm.di.jaxrs,com.ibm.di.jaxrs.impl,com.ibm.di.jaxrs.jackson,com.ibm.di.jaxrs.storage.atom,com.ibm.di.log,com.ibm.di.log.slf4j,com.ibm.di.log.slf4j-tdi,com.ibm.di.schema,com.ibm.di.server,com.ibm.di.server.entry,com.ibm.di.systemqueue,com.ibm.di.tp.server,com.ibm.di.ui.easyetl,com.ibm.di.ui.webui,com.ibm.di.util,com.ibm.di.web.common,com.ibm.tdi.rest,org.eclipse.equinox.http.jetty.listener
[exec] !ENTRY org.eclipse.emf.java.edit 2 0 2023-05-26 22:16:36.924
[exec] !MESSAGE Could not resolve module: org.eclipse.emf.java.edit [246]
[exec] !ENTRY org.eclipse.emf.converter 2 0 2023-05-26 22:16:36.925
[exec] !MESSAGE Could not resolve module: org.eclipse.emf.converter [669]
[exec] !ENTRY org.eclipse.emf.codegen 2 0 2023-05-26 22:16:36.925
[exec] !MESSAGE Could not resolve module: org.eclipse.emf.codegen [204]
[exec] !ENTRY org.eclipse.emf.exporter 2 0 2023-05-26 22:16:36.926
[exec] !MESSAGE Could not resolve module: org.eclipse.emf.exporter [670]
[exec] !ENTRY org.eclipse.emf.importer 2 0 2023-05-26 22:16:36.926
[exec] !MESSAGE Could not resolve module: org.eclipse.emf.importer [672]
[exec] !ENTRY org.eclipse.emf.importer.java 2 0 2023-05-26 22:16:36.927
[exec] !MESSAGE Could not resolve module: org.eclipse.emf.importer.java [673]
[exec] !ENTRY org.eclipse.emf.examples.generator.validator 2 0 2023-05-26 22:16:36.927
[exec] !MESSAGE Could not resolve module: org.eclipse.emf.examples.generator.validator [227]
[exec] !ENTRY org.eclipse.emf.ecore.sdo.editor 2 0 2023-05-26 22:16:36.927
[exec] !MESSAGE Could not resolve module: org.eclipse.emf.ecore.sdo.editor [219]
[exec] !ENTRY org.eclipse.emf.exporter.html 2 0 2023-05-26 22:16:36.928
[exec] !MESSAGE Could not resolve module: org.eclipse.emf.exporter.html [671]
[exec] !ENTRY org.eclipse.emf.java 2 0 2023-05-26 22:16:36.928
[exec] !MESSAGE Could not resolve module: org.eclipse.emf.java [245]
[exec] !ENTRY org.eclipse.ecf.provider.filetransfer.ssl 2 0 2023-05-26 22:16:36.928
[exec] !MESSAGE Could not resolve module: org.eclipse.ecf.provider.filetransfer.ssl [369]
[exec] Unresolved requirement: Fragment-Host: org.eclipse.ecf.provider.filetransfer; bundle-version="2.0.0"
[exec] !ENTRY org.eclipse.emf.codegen.ecore 2 0 2023-05-26 22:16:36.929
[exec] !MESSAGE Could not resolve module: org.eclipse.emf.codegen.ecore [205]
[exec] !ENTRY org.eclipse.emf.ant 2 0 2023-05-26 22:16:36.929
[exec] !MESSAGE Could not resolve module: org.eclipse.emf.ant [668]
[exec] !ENTRY org.eclipse.emf.importer.rose 2 0 2023-05-26 22:16:36.929
[exec] !MESSAGE Could not resolve module: org.eclipse.emf.importer.rose [674]
[exec] !ENTRY org.eclipse.xsd.ecore.importer 2 0 2023-05-26 22:16:36.930
[exec] !MESSAGE Could not resolve module: org.eclipse.xsd.ecore.importer [676]
[exec] !ENTRY org.eclipse.ecf.ssl 2 0 2023-05-26 22:16:36.930
[exec] !MESSAGE Could not resolve module: org.eclipse.ecf.ssl [371]
[exec] !ENTRY org.eclipse.xsd.ecore.exporter 2 0 2023-05-26 22:16:36.930
[exec] !MESSAGE Could not resolve module: org.eclipse.xsd.ecore.exporter [675]
[exec] !ENTRY org.eclipse.osgi 4 0 2023-05-26 22:16:36.931
[exec] !MESSAGE Application error
[exec] !STACK 1
[exec] java.lang.reflect.InvocationTargetException
[exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[exec] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
[exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[exec] at java.lang.reflect.Method.invoke(Method.java:498)
[exec] at org.eclipse.ant.core.AntRunner.run(AntRunner.java:514)
[exec] at org.eclipse.ant.core.AntRunner.start(AntRunner.java:611)
[exec] at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
[exec] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
[exec] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
[exec] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
[exec] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
[exec] at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
[exec] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
[exec] at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
[exec] at org.eclipse.equinox.launcher.Main.main(Main.java:1420)
[exec] Caused by: /home/sdi/SDI/tools_git/eclipse/eclipse_runtime/4.16/eclipse/plugins/org.eclipse.pde.build_3.10.800.v20200410-1419/scripts/build.xml:35: The following error occurred while executing this line:
[exec] /home/sdi/SDI/tools_git/eclipse/eclipse_runtime/4.16/eclipse/plugins/org.eclipse.pde.build_3.10.800.v20200410-1419/scripts/build.xml:51: The following error occurred while executing this line:
[exec] /home/sdi/SDI/export/osgi/builder/customTargets.xml:90: Problem: failed to create task or type eclipse.generateFeature
[exec] Cause: The name is undefined.
[exec] Action: Check the spelling.
[exec] Action: Check that any custom tasks/types have been declared.
[exec] Action: Check that any <presetdef>/<macrodef> declarations have taken place.
[exec] at org.apache.tools.ant.ProjectHelper.addLocationToBuildException(ProjectHelper.java:571)
[exec] at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:440)
[exec] at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget.java:106)
[exec] at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292)
[exec] at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:99)
[exec] at org.apache.tools.ant.Task.perform(Task.java:350)
[exec] at org.apache.tools.ant.Target.execute(Target.java:449)
[exec] at org.apache.tools.ant.Target.performTasks(Target.java:470)
[exec] at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1391)
[exec] at org.apache.tools.ant.Project.executeTarget(Project.java:1364)
[exec] at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
[exec] at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.executeTargets(EclipseDefaultExecutor.java:34)
[exec] at org.apache.tools.ant.Project.executeTargets(Project.java:1254)
[exec] at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:712)
[exec] at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:573)
[exec] ... 19 more
[exec] Caused by: /home/sdi/SDI/tools_git/eclipse/eclipse_runtime/4.16/eclipse/plugins/org.eclipse.pde.build_3.10.800.v20200410-1419/scripts/build.xml:51: The following error occurred while executing this line:
[exec] at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
[exec] at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(SingleCheckExecutor.java:36)
[exec] at org.eclipse.ant.internal.core.ant.EclipseSingleCheckExecutor.executeTargets(EclipseSingleCheckExecutor.java:32)
[exec] at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:437)
[exec] ... 36 more
[exec] Caused by: /home/sdi/SDI/export/osgi/builder/customTargets.xml:90: Problem: failed to create task or type eclipse.generateFeature
[exec] at org.apache.tools.ant.UnknownElement.getNotFoundException(UnknownElement.java:497)
[exec] at org.apache.tools.ant.UnknownElement.makeObject(UnknownElement.java:429)
[exec] at org.apache.tools.ant.UnknownElement.maybeConfigure(UnknownElement.java:165)
[exec] at org.apache.tools.ant.Task.perform(Task.java:349)
[exec] ... 49 more
[exec] Root exception:
[exec] /home/sdi/SDI/tools_git/eclipse/eclipse_runtime/4.16/eclipse/plugins/org.eclipse.pde.build_3.10.800.v20200410-1419/scripts/build.xml:35: The following error occurred while executing this line:
Re: Upgrading to Eclipse SDK 4.16 [message #1859290 is a reply to message #1859289] Fri, 26 May 2023 13:52 Go to previous messageGo to next message
You are upgrading from a 10 year old to 3 year old version of Eclipse. In that time, Java has sprung back to life making simple upgrades much harder; recent Eclipse releases have a Java 11 minimum and increasing. You should certainly not expect such a large upgrade to work; far too much has changed.
If you want Eclipse 4.16, then create a fresh 4.16 installation. YOu can re-use the workspace, though you might be well-advised to take a copy first. This should ensure that you use a compatible version of the EMF plugins.
Ed Willink
Re: Upgrading to Eclipse SDK 4.16 [message #1859292 is a reply to message #1859290] Sat, 27 May 2023 02:01 Go to previous message
I'm not sure they are updating. They mentioned upgrading. But didn't say how they did that. They show what appears to be some Ant task running that require EMF things but are using ancient versions such as 2.9.1.v20130902-0605. There's even org.eclipse.emf.ecore.sdo.editor in that list but goodness knows that hasn't existed in a very long time. Definitely better to start with a fresh installation and a fresh workspace.
Previous Topic:Eclipse crashes when COPY/PASTING
Next Topic:Eclipse displays incorrect warning when using Junit's @MethodSource
Current Time: Sun Jul 20 16:40:09 EDT 2025
Powered by FUDForum. Page generated in 0.43145 seconds
