Home » Modeling » EMF » Diagnostician Validation only enforce unique Ids after saving the model(The validation method of the Diagnostician is not behaving in an expected way.)
Diagnostician Validation only enforce unique Ids after saving the model [message #1859213] Fri, 19 May 2023 18:12 Go to next message
I have a meta model and I want to create and validate a model programmatically. I was verifying if marking the "name" attribute as id would prevent 2 groups with the same name from being stored in the model and it works but only after saving the model (it doesn't matter when I save the model, only as long as it's before validating).
Tournament tournament = TournamentFactory.eINSTANCE.createTournament();
tournament.setName("FIFA World Cup 2014");
//ResourceHelper.INSTANCE.saveResource(tournament, "examples/WorldCup2014.tournament");
Group groupG = TournamentFactory.eINSTANCE.createGroup();
groupG.setName("Group G");
Group groupA = TournamentFactory.eINSTANCE.createGroup();
groupA.setName("Group G");
validate(tournament);
When running the above, I get no validation errors but if I uncomment the line where the empty model is saved, I get:
Validation Error for: com.mattsch.emf.examples.tournament.impl.TournamentImpl@68c72235 (name: FIFA World Cup 2014)
    [com.mattsch.emf.examples.tournament.impl.GroupImpl@4738a206 (name: Group G), com.mattsch.emf.examples.tournament.impl.GroupImpl@66d3eec0 (name: Group G), Group G]
    The ID 'Group G' of 'com.mattsch.emf.examples.tournament.impl.GroupImpl@4738a206{examples/WorldCup2014.tournament#Group G}' collides with that of 'com.mattsch.emf.examples.tournament.impl.GroupImpl@66d3eec0{examples/WorldCup2014.tournament#Group G}'
I don't know why it only flags the error after saving the model and I would like it to be flagged without having to save the model. Is that possible?
The "name" attribute is marked as ordered, unique, changeable and ID in the class diagram. Here is the save() method as reference:
public void saveResource(EObject model, String file) {
        Resource resource = resourceSet.createResource(URI.createFileURI(file));
        resource.getContents().add(model);
        try {
            resource.save(Collections.EMPTY_MAP);
        } catch (IOException e) {
            System.err.println("Error saving model: " + e.getLocalizedMessage());
Thank you in advance :)
Re: Diagnostician Validation only enforce unique Ids after saving the model [message #1859217 is a reply to message #1859213] Sat, 20 May 2023 00:51 Go to previous messageGo to next message
It's not only validated after saving, it's validated by org.eclipse.emf.ecore.util.EObjectValidator.validate_UniqueID(EObject, DiagnosticChain, Map<Object, Object>) that it's unique within in the scope of the containing resource:
  public boolean validate_UniqueID(EObject eObject, DiagnosticChain diagnostics, Map<Object, Object> context)
    boolean result = true;
    String id = EcoreUtil.getID(eObject);
    if (id != null)
      Resource resource = eObject.eResource();
      if (resource != null)
        EObject otherEObject = resource.getEObject(id);
        if (eObject != otherEObject && otherEObject != null)
          result = false;
          if (diagnostics != null)
            diagnostics.add
              (createDiagnostic
                (Diagnostic.ERROR,
                 DIAGNOSTIC_SOURCE,
                 EOBJECT__UNIQUE_ID,
                 "_UI_DuplicateID_diagnostic",
                 new Object []
                   id,
                   getObjectLabel(eObject, context),
                   getObjectLabel(otherEObject, context)
                 new Object [] { eObject, otherEObject, id },
                 context));
    return result;
Re: Diagnostician Validation only enforce unique Ids after saving the model [message #1859220 is a reply to message #1859217] Sat, 20 May 2023 14:03 Go to previous messageGo to next message
Ah ok I see.
I found a workaround by using OCL in Ecore.
Thank you !
Re: Diagnostician Validation only enforce unique Ids after saving the model [message #1859221 is a reply to message #1859220] Sat, 20 May 2023 15:50 Go to previous messageGo to next message
OCLinEcore may be a bit more aggressive in validating, particularly before the first edit, but I wouldn't expect it to validate Ecore constraints better than the Sample Ecore Model Editor's Validate menu entry.
Are you sure you are using the correct Validate? WTP unfortunately installs a second "Validate" that does nothing. This is a very longstanding bug that they now regard as a legacy requirement.
Ed Willink
Re: Diagnostician Validation only enforce unique Ids after saving the model [message #1859222 is a reply to message #1859221] Sat, 20 May 2023 16:05 Go to previous messageGo to next message
Are you sure you mean to use the Ecore "id"? Whereas UML's "id" is specified to be unique within a namespace and so could be respected by a manual edit, Ecore's "id" is unique for the whole model and so can really only be accurate when computed programmatically. I have occasionally thought that EMF's "id" might solve a problem for me but no; it never seems useful.
To enforce uniqueness you are probably better off with an OCL constraint something like: groups->isUnique(name)
Ed Willink
Re: Diagnostician Validation only enforce unique Ids after saving the model [message #1859223 is a reply to message #1859222] Sat, 20 May 2023 16:50 Go to previous message
I'm using
Diagnostician.INSTANCE.validate(EObject);
It works well to validate the ocl constraints I create. It also works for the class diagram constraints (but with the resource thing for unique ids like explained earlier)
Yes this is exactly what I did and it works well
invariant
uniqueNames('[Group:uniqueNames]Each group\'s name must be different within the same tournament.'):
groups->isUnique(name);
I also love how easy it is to make custom error messages so I'm actually glad the diagnostician did not work as I expected with the class diagram :)
Previous Topic:Interplay of XML_MAP and XML_EXTENDED
Next Topic:Hierarchical constraint categories in plugin.xml
Current Time: Sun Jul 20 13:06:17 EDT 2025
Powered by FUDForum. Page generated in 0.03901 seconds
