Home » Eclipse Projects » Kura » Difference between "device.custom-name" & "Device Custom-Name"
Difference between "device.custom-name" & "Device Custom-Name" [message #1858666] Fri, 14 April 2023 06:29 Go to next message
Hi.
I am currently trying to configure my Kura (5.3.0) via Kapua.
After I save the changes made in Kapua a new snapshot is saved, if I try to change the Device Custom-Name, the changes are made in the kuraconfig.xml under name="Device Custom-Name", but in Kapua the name is still the value of "device.custom-name". "device.display-name" is set to custom.
If you have an idea what to do, please comment.
Re: Difference between "device.custom-name" & "Device Custom-Name" [message #1858667 is a reply to message #1858666] Fri, 14 April 2023 06:31 Go to previous messageGo to next message
does the value get set up properly after a reboot of the gateway?
Re: Difference between "device.custom-name" & "Device Custom-Name" [message #1858668 is a reply to message #1858667] Fri, 14 April 2023 06:49 Go to previous message
No. The value doesn't change.
Not after refreshing, or rebooting of the device.
Previous Topic:Eclipse Kura 5 Deploy Script (bulk deploy)
Next Topic:Forum closed
Current Time: Sun Jul 20 09:55:02 EDT 2025
Powered by FUDForum. Page generated in 0.26167 seconds
