Home » Modeling » TMF (Xtext) » Maven build does not find xcore lib?
Maven build does not find xcore lib? [message #1858508] Wed, 05 April 2023 09:40 Go to next message
Hello all,
I've just updated to JRE 17 and Tycho 3.0.4. Almost all builds are running fine again, except the DSL bundle.
I also applied the following version increments:
  • ecore-xcore: updated from 1.11.0 to 1.24.0
  • ecore-xcore-lib: updated from 1.4.0 to 1.7.0
  • ecore-xtext: updated from 1.5.0 to 1.7.0
  • emf: updated from 2.20.0 to 2.33.0
  • emf-codegen: updated from 2.19.0 to 2.23.0
  • emf-common: updated from 2.17.0 to 2.28.0
  • mwe2: updated from 2.11.3 to 2.14.0
Here is the current error output:
Execution default of goal org.eclipse.xtext:xtext-maven-plugin:2.30.0:generate failed: Plugin org.eclipse.xtext:xtext-maven-plugin:2.30.0 or one of its dependencies could not be resolved:
Failed to collect dependencies at org.eclipse.xtext:xtext-maven-plugin:jar:2.30.0
-> org.eclipse.emf:org.eclipse.emf.ecore.xcore:jar:1.24.0
-> org.eclipse.emf:org.eclipse.emf.ecore.xcore.lib:jar:[1.7.0,2.0.0):
No versions available for org.eclipse.emf:org.eclipse.emf.ecore.xcore.lib:jar:[1.7.0,2.0.0) within specified range -> [Help 1]
I found our that there seems to be a version 1.7.0 at https://mvnrepository.com/artifact/org.eclipse.emf/org.eclipse.emf.ecore.xcore.lib. Do you have an idea what could be wrong here? Do I maybe need to downgrade something?
Thank you very much for your assistance.
[Updated on: Wed, 05 April 2023 09:41] by Moderator
Re: Maven build does not find xcore lib? [message #1858509 is a reply to message #1858508] Wed, 05 April 2023 09:47 Go to previous messageGo to next message
Can you provide a reproducer
And double check you run maven with -U
[Updated on: Wed, 05 April 2023 10:02] by Moderator
Re: Maven build does not find xcore lib? [message #1858516 is a reply to message #1858509] Wed, 05 April 2023 10:44 Go to previous message
-U did it. Thanks Christian! Need to add that flag to my notes.
Previous Topic:Identation in xtend template with tracing
Next Topic:Tracing resource location
Current Time: Sun Jul 20 10:27:02 EDT 2025
Powered by FUDForum. Page generated in 0.03675 seconds
