Re: Unable to use external jar files with Eclipse 2022-12 [message #1857786 is a reply to message #1857430] |
Sat, 25 February 2023 13:59  |
Good Information
Make sure that the jar file is included in your project's build path. To do this, right-click on your project in the Project Explorer, select "Properties", then "Java Build Path", and click on the "Libraries" tab. From there, you can add the jar file to your project's classpath.
Check that the jar file is in the correct location. Eclipse expects jar files to be located in the project's "lib" folder by default. If the jar file is not in the correct location, you may need to move it or update your project's build path to point to the correct location. Best Regards
Check that the jar file is not corrupt or incompatible with your project. Try opening the jar file with a tool like 7-Zip or WinRAR to make sure that it contains the files you expect. You may also want to check the documentation or release notes for the jar file to make sure that it is compatible with your project.
FUDForum. Page generated in 0.05262 seconds
