Home » Language IDEs » Java Development Tools (JDT) » The extension took too long to return from the computeCompletionProposals()' operation.
The extension took too long to return from the computeCompletionProposals()' operation. [message #1857588] Wed, 15 February 2023 21:15 Go to next message
When I type new some constructor in eclipse ,it pop up the message : "The 'org.eclipse.jdt.ui.JavaAllCompletionProposalComputer' proposal computer from the 'org.eclipse.jdt.ui' plug-in did not complete normally. The extension took too long to return from the computeCompletionProposals()' operation."
It just occurred when typing new constructors, normal class proposals works well.
it occurs in all of eclipse 2022-06/2022-09/2022-12 . My system is macOs 12.5.1
Can some one help me for this issue.
Re: The extension took too long to return from the computeCompletionProposals()' operation. [message #1857590 is a reply to message #1857588] Thu, 16 February 2023 03:35 Go to previous messageGo to next message
Looks like a bug to me. But to confirm, can you go the log files and let us know if there's something there. Or you can simply share the log file here, so I can take a look.
Re: The extension took too long to return from the computeCompletionProposals()' operation. [message #1857632 is a reply to message #1857590] Fri, 17 February 2023 04:43 Go to previous message
tks for reply. Here is the whole log:
!SESSION 2023-02-17 17:36:54.126 -----------------------------------------------
eclipse.buildId=4.24.0.I20220607-0700
java.version=11.0.12
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=zh_CN_#Hans
Framework arguments: -product org.eclipse.epp.package.jee.product -keyring /Users/tanyuefa/.eclipse_keyring
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.jee.product -keyring /Users/tanyuefa/.eclipse_keyring
!ENTRY org.eclipse.jface 2 0 2023-02-17 17:36:59.714
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2023-02-17 17:36:59.714
!MESSAGE A conflict occurred for COMMAND+SHIFT+T:
Binding(COMMAND+SHIFT+T,
ParameterizedCommand(Command(org.eclipse.jdt.ui.navigate.open.type,Open Type,
Open a type in a Java editor,
Category(org.eclipse.ui.category.navigate,Navigate,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@ce5a2ea,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.lsp4e.symbolinworkspace,Go to Symbol in Workspace,
Category(org.eclipse.lsp4e.category,Language Servers,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@37a0c3c6,
,,true),null),
!MESSAGE A conflict occurred for ALT+COMMAND+R:
Binding(ALT+COMMAND+R,
ParameterizedCommand(Command(org.eclipse.ui.edit.rename,Rename,
Rename the selected item,
Category(org.eclipse.ui.category.file,File,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@5de32e00,
,,true),null),
org.eclipse.ui.contexts.window,,cocoa,system)
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.rename.element,Rename - Refactoring ,
Rename the selected element,
Category(org.eclipse.jdt.ui.category.refactoring,Refactor - Java,Java Refactoring Actions,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@219ec4b6,
,,true),null),
!ENTRY org.eclipse.m2e.logback.appender 4 0 2023-02-17 17:37:07.368
!MESSAGE Fallback to *.zip also failed: java.io.FileNotFoundException: /usr/local/var/.m2/repository/.cache/m2e/1.18.4/a6fdb7a332e7cf3548b2dd103940947f/nexus-maven-repository-index.zip (No such file or directory)
!ENTRY org.eclipse.m2e.logback.appender 4 0 2023-02-17 17:37:07.374
!MESSAGE Unable to update index for snapshots|http://nexus.xxxx.com.cn/nexus/repository/snapshots/
!STACK 0
java.io.IOException: Resetting to invalid mark
at java.base/java.io.BufferedInputStream.reset(BufferedInputStream.java:454)
at org.apache.maven.index.updater.IndexDataReader.<init>(IndexDataReader.java:69)
at org.apache.maven.index.updater.DefaultIndexUpdater.unpackIndexData(DefaultIndexUpdater.java:385)
at org.apache.maven.index.updater.DefaultIndexUpdater.loadIndexDirectory(DefaultIndexUpdater.java:202)
at org.apache.maven.index.updater.DefaultIndexUpdater.access$300(DefaultIndexUpdater.java:76)
at org.apache.maven.index.updater.DefaultIndexUpdater$LuceneIndexAdaptor.setIndexFile(DefaultIndexUpdater.java:518)
at org.apache.maven.index.updater.DefaultIndexUpdater.fetchAndUpdateIndex(DefaultIndexUpdater.java:736)
at org.apache.maven.index.updater.DefaultIndexUpdater.fetchAndUpdateIndex(DefaultIndexUpdater.java:161)
at org.eclipse.m2e.core.internal.index.nexus.NexusIndexManager.updateRemoteIndex(NexusIndexManager.java:1171)
at org.eclipse.m2e.core.internal.index.nexus.NexusIndexManager.updateIndex(NexusIndexManager.java:1115)
at org.eclipse.m2e.core.internal.index.nexus.NexusIndexManager.lambda$0(NexusIndexManager.java:680)
at org.eclipse.m2e.core.internal.index.nexus.IndexUpdaterJob.run(IndexUpdaterJob.java:77)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
!ENTRY org.eclipse.m2e.logback.appender 4 0 2023-02-17 17:37:07.559
!MESSAGE Fallback to *.zip also failed: java.io.FileNotFoundException: /usr/local/var/.m2/repository/.cache/m2e/1.18.4/75c36b606121863e8fed512af013a0e0/nexus-maven-repository-index.zip (No such file or directory)
!ENTRY org.eclipse.m2e.logback.appender 4 0 2023-02-17 17:37:07.561
!MESSAGE Unable to update index for releases|http://nexus.xxx.com.cn/nexus/repository/releases/
!STACK 0
!ENTRY org.eclipse.m2e.logback.appender 4 0 2023-02-17 17:37:08.307
!MESSAGE Fallback to *.zip also failed: java.io.FileNotFoundException: /usr/local/var/.m2/repository/.cache/m2e/1.18.4/11cc140ee4e0c6a5d0dde4a89371e513/nexus-maven-repository-index.zip (No such file or directory)
!ENTRY org.eclipse.m2e.logback.appender 4 0 2023-02-17 17:37:08.309
!MESSAGE Unable to update index for alimaven|http://maven.aliyun.com/nexus/content/groups/public/
!STACK 0
!ENTRY org.eclipse.jdt.ui 2 0 2023-02-17 17:39:59.106
!MESSAGE The 'org.eclipse.jdt.ui.JavaAllCompletionProposalComputer' proposal computer from the 'org.eclipse.jdt.ui' plug-in did not complete normally. The extension took too long to return from the 'computeCompletionProposals()' operation.
[Updated on: Fri, 17 February 2023 04:46] by Moderator
Previous Topic:Passing the `release` option to the compiler
Next Topic:Repository error in HANA Development Tools
Current Time: Sun Jul 20 15:20:15 EDT 2025
Powered by FUDForum. Page generated in 0.04324 seconds
