Home » Modeling » TMF (Xtext) » Language server respond with error missing header in mac(Language server respond with error missing header in mac)
Language server respond with error missing header in mac [message #1857349] Wed, 01 February 2023 07:40 Go to next message
I have installed vscode extension in mac book, language server responded with error missing header.
I found this github issue https://github.com/eclipse/lsp4j/issues/210 with the same stack trace.
We have a server which is IO mode.
Why i am facing this issue in macbook only? It works in windows.
It bits strange for me why language client will send request without header.
Installed extension in vscode version 1.74.3(Both windows and mac have same vscode)
Any hint and suggestions it would be great help.
Nagaraj
[Updated on: Wed, 01 February 2023 07:47] by Moderator
Re: Language server failed to respond with error missing header in mac [message #1857350 is a reply to message #1857349] Wed, 01 February 2023 07:42 Go to previous messageGo to next message
question:
- which xtext version
- lsp4j version
do you use?
and are you using websocket.
i never saw this problem on any of my examples on mac
Re: Language server failed to respond with error missing header in mac [message #1857351 is a reply to message #1857350] Wed, 01 February 2023 07:43 Go to previous messageGo to next message
can you also please try https://github.com/cdietrich/xtext-languageserver-example-simple
Re: Language server failed to respond with error missing header in mac [message #1857352 is a reply to message #1857350] Wed, 01 February 2023 07:50 Go to previous messageGo to next message
To answer your question:
- which xtext version: 2.29.0
- lsp4j version 0.19
and are you using websocket. I am running server in IO mode (basically with type script we are invoking server)
Sure will try your suggestion.
[Updated on: Wed, 01 February 2023 08:10] by Moderator
Re: Language server failed to respond with error missing header in mac [message #1857354 is a reply to message #1857352] Wed, 01 February 2023 07:58 Go to previous messageGo to next message
no i am using io
run : { command: script },
the socket part is commented out
maybe you have something that spoils the io stream with unexpected messages
e.g. via some logging or println
[Updated on: Wed, 01 February 2023 07:59] by Moderator
Re: Language server failed to respond with error missing header in mac [message #1857361 is a reply to message #1857354] Wed, 01 February 2023 11:54 Go to previous messageGo to next message
I am new bit new to mac book, for mac extension i am using shell script to start server if i change shell script permission(chmod 755) to read write and execute i got below error.
023-02-01 16:34:31.513 [error] Error: Header must provide a Content-Length property.
at StreamMessageReader.onData (/Users/ngk/.vscode/extensions/myextension-mac-extension-0.0.2/node_modules/vscode-jsonrpc/lib/common/messageReader.js:138:27)
at Socket.<anonymous> (/Users/ngk/.vscode/extensions/myextension-mac-extension-0.0.2/node_modules/vscode-jsonrpc/lib/common/messageReader.js:122:18)
at Socket.emit (node:events:526:28)
at addChunk (node:internal/streams/readable:315:12)
at readableAddChunk (node:internal/streams/readable:289:9)
at Readable.push (node:internal/streams/readable:228:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
if i don't change permission i am getting notification from server like ''Request has failed ''
something is going wrong with vscode extension execution.
is it related to some permission issues which is causing extension to not work in macbook.
any suggestions since i don't have my workspace setup in macbook i am just relying on console logs of vscode.
some how io steam is getting spoiled or request formation from client is not correct or some permissions issue .
I am launching vscode from download folder and installed extension.
every bit of code is same except shell script to launch server (No issue in windows )
Re: Language server failed to respond with error missing header in mac [message #1857362 is a reply to message #1857361] Wed, 01 February 2023 12:50 Go to previous messageGo to next message
can you please try my example with ./gradlew clean build startCode
you also might change the script to enable remote debugging and then remote debug what actually arrives.
[Updated on: Wed, 01 February 2023 12:51] by Moderator
Re: Language server failed to respond with error missing header in mac [message #1857363 is a reply to message #1857362] Wed, 01 February 2023 14:06 Go to previous messageGo to next message
maybe you can also share a minimum reproducing example
Re: Language server failed to respond with error missing header in mac [message #1857364 is a reply to message #1857363] Wed, 01 February 2023 15:08 Go to previous messageGo to next message
you might also alter the launch script to do
-log debug -trace (dont know to what . dir this is written to)
set -- \
-classpath "$CLASSPATH" \
org.eclipse.xtext.ide.server.ServerLauncher \
"-log" "debug" "-trace"
may log into the folder/project you open in code to test.
so you might use this
launcher class instead
package org.xtext.example.mydsl.ide;
import java.io.ByteArrayInputStream;
import java.io.FileOutputStream;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.io.PrintStream;
import java.io.PrintWriter;
import java.util.concurrent.Future;
import org.eclipse.lsp4j.jsonrpc.Launcher;
import org.eclipse.lsp4j.services.LanguageClient;
import org.eclipse.xtext.ide.server.LanguageServerImpl;
import org.eclipse.xtext.ide.server.LaunchArgs;
import org.eclipse.xtext.ide.server.ServerModule;
import org.eclipse.xtext.xbase.lib.Exceptions;
import org.eclipse.xtext.xbase.lib.InputOutput;
import com.google.common.base.Objects;
import com.google.common.io.ByteStreams;
import com.google.inject.Guice;
import com.google.inject.Inject;
public class MyServerLauncher {
	public static final String LOG = "-log";
	public static final String TRACE = "-trace";
	public static final String NO_VALIDATE = "-noValidate";
		launch(MyServerLauncher.class.getName(), new String[] {"-log", "debug", "-trace"}, new ServerModule());
	public static void launch(String prefix, String[] args, com.google.inject.Module... modules) {
		LaunchArgs launchArgs = createLaunchArgs(prefix, args);
		MyServerLauncher launcher = Guice.createInjector(modules).<MyServerLauncher>getInstance(MyServerLauncher.class);
		launcher.start(launchArgs);
	@Inject
	private LanguageServerImpl languageServer;
	public void start(LaunchArgs args) {
		try {
			InputOutput.println("Xtext Language Server is starting.");
			Launcher<LanguageClient> launcher = Launcher.createLauncher(languageServer,
					LanguageClient.class, args.getIn(), args.getOut(), args.isValidate(), args.getTrace());
			languageServer.connect(launcher.getRemoteProxy());
			Future<Void> future = launcher.startListening();
			InputOutput.println("Xtext Language Server has been started.");
			while (!future.isDone()) {
				Thread.sleep(10_000L);
		} catch (InterruptedException e) {
			throw Exceptions.sneakyThrow(e);
	public static LaunchArgs createLaunchArgs(String prefix, String[] args) {
		LaunchArgs launchArgs = new LaunchArgs();
		launchArgs.setIn(System.in);
		launchArgs.setOut(System.out);
		redirectStandardStreams(prefix, args);
		launchArgs.setTrace(getTrace(args));
		launchArgs.setValidate(shouldValidate(args));
		return launchArgs;
	public static PrintWriter getTrace(String[] args) {
		if (shouldTrace(args)) {
			return createTrace();
		return null;
	public static PrintWriter createTrace() {
		return new PrintWriter(System.out);
	public static void redirectStandardStreams(String prefix, String[] args) {
		if (shouldLogStandardStreams(args)) {
			logStandardStreams(prefix);
		} else {
			silentStandardStreams();
	public static boolean shouldValidate(String[] args) {
		return !testArg(args, MyServerLauncher.NO_VALIDATE);
	public static boolean shouldTrace(String[] args) {
		return testArg(args, MyServerLauncher.TRACE);
	public static boolean shouldLogStandardStreams(String[] args) {
		return testArg(args, MyServerLauncher.LOG, "debug");
	public static boolean testArg(String[] args, String... values) {
		for (String arg : args) {
			if (testArg(arg, values)) {
				return true;
		return false;
	public static boolean testArg(String arg, String... values) {
		for(String value : values) {
			if (Objects.equal(value, arg)) {
				return true;
		return false;
	public static void logStandardStreams(String prefix) {
		try {
			FileOutputStream stdFileOut = new FileOutputStream(System.getProperty("user.home")+"/"+prefix + "-debug.log");
			redirectStandardStreams(stdFileOut);
		} catch (IOException e) {
	public static void silentStandardStreams() {
		redirectStandardStreams(silentOut());
	public static void redirectStandardStreams(OutputStream out) {
		redirectStandardStreams(silentIn(), out);
	public static void redirectStandardStreams(InputStream in, OutputStream out) {
		System.setIn(in);
		System.setOut(new PrintStream(out));
	public static OutputStream silentOut() {
		return ByteStreams.nullOutputStream();
	public static InputStream silentIn() {
		return new ByteArrayInputStream(new byte[0]);
which will log to ~/org.xtext.example.mydsl.ide.MyServerLauncher-debug.log
[Updated on: Wed, 01 February 2023 15:33] by Moderator
Re: Language server failed to respond with error missing header in mac [message #1857366 is a reply to message #1857364] Thu, 02 February 2023 01:25 Go to previous message
@Christian Dietrich Thank you will try your suggestion.
Previous Topic:Xtext 2.30.0.M2 is out
Next Topic:Data Type Rule
Current Time: Sun Jul 20 18:08:32 EDT 2025
Powered by FUDForum. Page generated in 0.06281 seconds
