cannot get remote repository refs [message #1856649] |
Tue, 20 December 2022 19:35  |
I am trying to upload/push a local repository to my GitHub at:
https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git
By choosing from the context menu of the repository I wish to push from the Package Explorer, Team>Remote> Push
And the Push to Another Repository dialog appears and I populate it accordingly to the attached screen shot..
When I press next Eclipse prompts for the username and password that I had previously supplied and after three attempts it logs me out with the following Error Message:
Transport Error: Cannot get remote repository refs.
https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git: not authorized
I should also note that Eclipse>Preferences>Version Control (Team)>Git>Configuration>User Settings I have set the following:
[user]
name = rmit-s9905648-mike-little
email = s9905648@student.rmit.edu.au
[filter "lfs"]
clean = git-lfs clean -- %f
smudge = git-lfs smudge -- %f
process = git-lfs filter-process
required = true
[http]
sslVerify = false
What can I do?
Re: cannot get remote repository refs [message #1856728 is a reply to message #1856719] |
Sun, 25 December 2022 20:48   |
1. OK created a Personal Access Token, defined a note, and defined an expiry date, but did not define any scope attributes.
2. Entered my Github username as the user for the destination Git Repository
3. Instead of using my Github password, I used the Personal Access Token that I had generated.
4. This time, Eclipse did not prompt for the username and password this time as it had done previously and appeared to be attempting to access the GitHub repository I had created.
5. Yet it failed, and it produced the following transport error message:
https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git: git-upload-pack not permitted on 'https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git/'
And....
org.eclipse.jgit.api.errors.TransportException: https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git: git-upload-pack not permitted on 'https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git/'
at org.eclipse.jgit.api.LsRemoteCommand.execute(LsRemoteCommand.java:192)
at org.eclipse.jgit.api.LsRemoteCommand.call(LsRemoteCommand.java:131)
at org.eclipse.egit.core.op.ListRemoteOperation.run(ListRemoteOperation.java:116)
at org.eclipse.egit.ui.internal.components.RefSpecPage$2.run(RefSpecPage.java:254)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:122)
Caused by: org.eclipse.jgit.errors.TransportException: https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git: git-upload-pack not permitted on 'https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git/'
at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:692)
at org.eclipse.jgit.transport.TransportHttp.openFetch(TransportHttp.java:465)
at org.eclipse.jgit.api.LsRemoteCommand.execute(LsRemoteCommand.java:170)
... 4 more
And..
eclipse.buildId=4.26.0.20221201-1200
java.version=18.0.1
java.vendor=Eclipse Adoptium
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_AU
Framework arguments: -product org.eclipse.epp.package.java.product -keyring /Users/mlittle-macmini-20200921/.eclipse_keyring
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.java.product -keyring /Users/mlittle-macmini-20200921/.eclipse_keyring
6. I am getting closer to resolution, but there are still problems... any suggestions?
FUDForum. Page generated in 0.11859 seconds
