Home » Eclipse Projects » Paho » How to connect to a digitransit broker using paho mqtt client(Receive public transport data using python paho mqtt client)
How to connect to a digitransit broker using paho mqtt client [message #1853526] Wed, 06 July 2022 10:04 Go to next message
I am pretty new to MQTT and I would like to establish a connection to a digitransit mqtt broker to receive public transportation data using python paho mqtt client. To connect to a broker the port and the topic is needed.
I am not sure if something is missing. Please not that the script is executed via browser based jupyter notebook.
- Port: 8883
- Topic: /hfp/v2/journey/#
- Broker: mqtt.hsl.fi
When running via command line the data can be received, e.g.
/hfp/v2/journey/ongoing/vp/bus/0022/01281/1040/2/Elielinaukio/14:29/1140118/0//// {"VP":{"desi":"40","dir":"2","oper":22,"veh":1281,"tst":"2022-07-06T11:56:53.417Z","tsi":1657108613,"spd":null,"hdg":null,"lat":null,"long":null,"acc":null,"dl":-101,"odo":8530,"drst":0,"oday":"2022-07-06","jrn":2646,"line":62,"start":"14:29","loc":"ODO","stop":null,"route":"1040","occu":0}}
You can try this out simply using two commands:
npm install -g mqtt
mqtt subscribe -h mqtt.hsl.fi -p 8883 -l mqtts -v -t "/hfp/v2/journey/#"
When running in a browser based jupyter notebook I only see the output that is defined on_connect method but no data shows up.
My code snippet is:
# pip install paho-mqtt
import paho.mqtt.client as mqtt
# The callback for when the client receives a CONNACK response from the server.
def on_connect(client, userdata, flags, rc):
    print("Connected with result code "+ str(rc))
    # Subscribing in on_connect() means that if we lose the connection and
    # reconnect then subscriptions will be renewed.
    client.subscribe("/hfp/v2/journey/#")
# The callback for when a PUBLISH message is received from the server.
def on_message(client, userdata, msg):
    print(msg.topic+" "+str(msg.payload))
client = mqtt.Client()
client.on_connect = on_connect
client.on_message = on_message
client.tls_set()
client.connect("mqtt.hsl.fi", 8883, 60)
client.loop_forever()
Does anyone know what kind of detail is wrong or missing?
Re: How to connect to a digitransit broker using paho mqtt client [message #1855585 is a reply to message #1853526] Fri, 21 October 2022 10:38 Go to previous message
Since you are going over TLS to port 8883, you need to at least set TLS parameters for the client, eg. lines 269 and 270 in our mqtt-stats.py at
https://github.com/gambitcomminc/mqtt-stats/blob/master/mqtt-stats.py
which is also published in the Eclipse Marketplace at
https://marketplace.eclipse.org/content/mqtt-stats
Previous Topic:RabbitMQ Server shutdown when connecting and disconnecting via org.eclipse.paho.client.mqttv3 broker
Next Topic:MQTT over Websockets - status code 302 redirect ?
Current Time: Sat Jul 19 09:55:06 EDT 2025
Powered by FUDForum. Page generated in 0.03164 seconds
