Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » USE external static library(USE external static library in linux)
USE external static library [message #1855413] Wed, 12 October 2022 20:54 Go to next message
Dear Alois
I want to call an external static library in the algorithm of a simple function block under linux. How do I do this
best regards
Re: USE external static library [message #1855425 is a reply to message #1855413] Thu, 13 October 2022 08:41 Go to previous messageGo to next message
I think for this the best is to make a SIFB. There you have more flexibility. you then can include the header files from the libary and call the methods from that lib. In your cmake you need to setup the linkage to that library. You can look into modules like OPC UA or MQTT for refernces what you need to do.
BR,
Alois
Re: USE external static library [message #1855490 is a reply to message #1855425] Mon, 17 October 2022 22:16 Go to previous messageGo to next message
Dear Alois
OK I Got it,
I modified the Txt document to achieve the function of adding static library
1. Add a dependency directory
Add "link_directories(/home/forte/linuxlib)" to forte/src/CMakeLists.txt.
2. Add a library name
Add "TERGET_LINK_LIBRARIES(forte ccspsl) "to forte/src/CMakeLists.txt
best regards
Re: USE external static library [message #1855562 is a reply to message #1855490] Thu, 20 October 2022 08:30 Go to previous message
Great!
Previous Topic:Error CBSDSocketInterface: bind() failed: Adress already in use
Next Topic:Tranformation from .sys to .fboot
Current Time: Sat Jul 19 06:38:29 EDT 2025
Powered by FUDForum. Page generated in 0.25243 seconds
