Home » Eclipse Projects » Oomph » Setup Tasks preference page missing
Setup Tasks preference page missing [message #1855379] Tue, 11 October 2022 10:06 Go to next message
My product used to have an Preferences > Oomph > Setup Tasks preference page. I don't see that page anymore. Was the page removed intentionally or should it still be there?
My product .setup file installs the following Oomph. Am I using the correct oomph repository URL ?
<setupTask
xsi:type="setup.p2:P2Task"
label="Oomph Setup UI">
<requirement
name="org.eclipse.oomph.setup.feature.group"/>
<repository
url="http://download.eclipse.org/oomph/updates"/>
<description>Added by IBM. P2 Director to install Oomph Updater.</description>
</setupTask>
Note that I am using the latest Eclipse Installer from https://projects.eclipse.org/projects/tools.oomph/downloads
Also, preferences I added to my .setup file using the Preference Recorder are no longer being set in my product installs. My guess is this problem is related to the Setup Tasks preference page being missing.
Thanks.
Re: Setup Tasks preference page missing [message #1855381 is a reply to message #1855379] Tue, 11 October 2022 10:38 Go to previous messageGo to next message
The preference pages should all be present. It sounds like perhaps the bundles aren't starting. The latest version requires Java 11 to run. Check the Error Log view for logged exceptions when the IDE starts.
Re: Setup Tasks preference page missing [message #1855385 is a reply to message #1855381] Tue, 11 October 2022 11:37 Go to previous messageGo to next message
Thanks for the super fast response!
My product curretly requires Java 8. I'm wondering what Oomph features will not work with by Java 8 product.
I see the following in the Error view.
!ENTRY org.eclipse.oomph.setup.editor 4 0 2022-10-10 17:30:40.571
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.oomph.setup.editor [513]
Unresolved requirement: Require-Bundle: org.eclipse.oomph.setup.ui; bundle-version="[1.22.0,2.0.0)"
-> Bundle-SymbolicName: org.eclipse.oomph.setup.ui; bundle-version="1.22.0.v20211116-0849"; singleton:="true"
org.eclipse.oomph.setup.ui [517]
Unresolved requirement: Require-Bundle: org.eclipse.userstorage.ui; bundle-version="[1.0.2,2.0.0)"; x-installation:="greedy"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.userstorage.oauth; bundle-version="[1.0.0,2.0.0)"; x-installation:="greedy"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.nebula.widgets.tablecombo; bundle-version="[1.0.0,2.0.0)"
-> Bundle-SymbolicName: org.eclipse.nebula.widgets.tablecombo; bundle-version="1.2.0.202208171909"
org.eclipse.nebula.widgets.tablecombo [492]
Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=11))"
at org.eclipse.osgi.container.Module.start(Module.java:444)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1682)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1661)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1624)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1555)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Re: Setup Tasks preference page missing [message #1855388 is a reply to message #1855385] Tue, 11 October 2022 12:44 Go to previous messageGo to next message
You'll have to use older versions of Oomph for Java 8. Sorry. I think the 2021-12, https://download.eclipse.org/oomph/drops/release/1.23.0/ is the last release the support Java 8.
Re: Setup Tasks preference page missing [message #1855428 is a reply to message #1855388] Thu, 13 October 2022 10:19 Go to previous message
Problem solved. Thank you so much!
Previous Topic:Exception when trying to run the installer or setup tasks
Next Topic:CheckoutConflictException in Oomph GitCloneTask since 2022-12 M2
Current Time: Sun Jul 20 09:05:12 EDT 2025
Powered by FUDForum. Page generated in 0.04796 seconds
