Other editor to use for debugging diagram issues [message #1855142] |
Thu, 29 September 2022 10:35  |
Core Question: Is there another editor than Papyrus' core editor, that would give me visibility into the meta data the diagrams have and the 'core' editor uses to display the content?
I searched the Wiki - yet couldn't find a way to help debug an issue I am having.
Background: Generally I export the diagrams I have in Papyrus out, and put into a design document. (I can describe why if you would like). When exporting often the model validation routines will catch diagramming errors. Often these errors produce exceptions in Java with call-stacks, and at times the net result is a diagram content will change (disconnected dependencies, etc). I've been dealing with this for years, yet...
I would like to explore the errors one layer lower, to help me fix the diagram. Some of these diagrams are for products, and while "it's always easier the second time" and I could redraw the diagram - it would helpful to me if I could dive one level lower. I tried going into Model Explorer, though, was trying to understand if there is a layer lower that I could use as well.
Sam
[Updated on: Thu, 29 September 2022 11:16] by Moderator
FUDForum. Page generated in 0.04527 seconds
