Home » Modeling » EMF » [CDO][NET4J] SSL and negotiator type="challenge"(SSL and negotiator type="challenge" not working)
[CDO][NET4J] SSL and negotiator type="challenge" [message #1854960] Tue, 20 September 2022 09:41 Go to next message
i would like to use the ssl acceptor. So I switched my config from:
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
 <negotiator type="challenge" description="@config/users"/>
</acceptor>
to
<acceptor type="ssl" listenAddr="0.0.0.0" port="443">
</acceptor>
SSL is working but the client is not able to connect.
If remove the negotiator everthing is working as it should:
So server side:
</acceptor>
and client:
final String connection = serverdns + ":" + 443;
/* create net4j config */
final IConnector connector = Net4jUtil.getConnector(IPluginContainer.INSTANCE, connectionType, connection);
final CDONet4jSessionConfiguration config = CDONet4jUtil.createNet4jSessionConfiguration();
		config.setConnector(connector);
		config.setRepositoryName(repositoryName);
	session = config.openNet4jSession();
Is working.
But with server side:
</acceptor>
and client:
/* create login processor */
		final PasswordCredentialsProvider credentialsProvider = new PasswordCredentialsProvider(user, password);
		loginPostProcessor = new ConnectorCredentialsInjector(connection, credentialsProvider);
		IPluginContainer.INSTANCE.addPostProcessor(loginPostProcessor);
It fails.
The same code with tcp acceptor works fine.
Has anyone the same problem? I use ne new version with TLS 1.3 from git.
Alexander
[Updated on: Tue, 20 September 2022 09:45] by Moderator
Re: [CDO][NET4J] SSL and negotiator type="challenge" [message #1854962 is a reply to message #1854960] Tue, 20 September 2022 12:04 Go to previous messageGo to next message
Hi Alexander,
The Net4j negotiators are not needed with CDO because CDO has its own Diffie/Hellman-based credendials exchange. Just get rid of the <negotiator> element under the <acceptor> element.
Re: [CDO][NET4J] SSL and negotiator type="challenge" [message #1854963 is a reply to message #1854962] Tue, 20 September 2022 12:14 Go to previous messageGo to next message
Hi Eike,
if I understand you right. I remove the <negotiator> and replace is by
<authenticator type="file" description="@config/users"/>
under repository on the server side.
On the client side I remove the PostProcessor and add to the config.
final var credentialsProvider = new PasswordCredentialsProvider(user, password);
final var config = CDONet4jUtil.createNet4jSessionConfiguration();
config.setCredentialsProvider(credentialsProvider);
this should use the CDO user authenication
Thank you for your help.
Alexander
Re: [CDO][NET4J] SSL and negotiator type="challenge" [message #1854967 is a reply to message #1854963] Tue, 20 September 2022 22:46 Go to previous message
Yes, that's it ;-)
Previous Topic:Create ecore annotation model and use it in another ecore model
Next Topic:Model not shown properly in Model Explorer
Current Time: Sun Jul 20 02:01:46 EDT 2025
Powered by FUDForum. Page generated in 0.03755 seconds
