Cannot create/update REST resource [message #1854199] |
Fri, 05 August 2022 10:49  |
Hi there everyone,
I'm having problems creating/updating REST resources on a remote server. The methods I'm using are shown below:
// POST
public Response post(ContactEntityDo entity) {
Map<String, String> params = Map.of("schema", SCHEMA_NAME);
JSONObject jsParams = new JSONObject(params);
WebTarget target = helper().target(RESOURCE_PATH).queryParam("params",
UriComponent.encode(jsParams.toString(), UriComponent.Type.QUERY_PARAM_SPACE_ENCODED));
return target.request().accept(MediaType.APPLICATION_JSON).post(Entity.json(entity),
Response.class);
// PUT
public Response put(ContactEntityDo entity) {
return target.request().accept(MediaType.APPLICATION_JSON).put(Entity.json(entity),
Response.class);
Here is the stacktrace
java.lang.NullPointerException: null
at org.eclipse.scout.apps.ygclient.client.rest.common.ResponseRestClientHelper.transformException(ResponseRestClientHelper.java:34)
at org.eclipse.scout.rt.rest.client.proxy.RestClientProxyFactory$RestProxyInvocationHandler.transformException(RestClientProxyFactory.java:256)
at org.eclipse.scout.rt.rest.client.proxy.RestClientProxyFactory$RestProxyInvocationHandler.invoke(RestClientProxyFactory.java:206)
at com.sun.proxy.$Proxy58.post(Unknown Source)
at org.eclipse.scout.apps.ygclient.client.rest.collaborator.contact.ContactRestResourceClient.post(ContactRestResourceClient.java:61)
at org.eclipse.scout.apps.ygclient.client.collaborator.contact.ContactForm$MainBox$GeneralBox$SaveButton.execClickAction(ContactForm.java:352)
at org.eclipse.scout.rt.client.ui.form.fields.button.AbstractButton$LocalButtonExtension.execClickAction(AbstractButton.java:515)
at org.eclipse.scout.rt.client.extension.ui.form.fields.button.ButtonChains$ButtonClickActionChain$1.callMethod(ButtonChains.java:59)
at org.eclipse.scout.rt.client.extension.ui.form.fields.button.ButtonChains$ButtonClickActionChain$1.callMethod(ButtonChains.java:1)
at org.eclipse.scout.rt.shared.extension.AbstractExtensionChain.callChain(AbstractExtensionChain.java:118)
at org.eclipse.scout.rt.client.extension.ui.form.fields.button.ButtonChains$ButtonClickActionChain.execClickAction(ButtonChains.java:62)
at org.eclipse.scout.rt.client.ui.form.fields.button.AbstractButton.interceptClickAction(AbstractButton.java:499)
at org.eclipse.scout.rt.client.ui.form.fields.button.AbstractButton.doClick(AbstractButton.java:341)
at org.eclipse.scout.rt.client.ui.form.fields.button.AbstractButton$P_UIFacade.fireButtonClickFromUI(AbstractButton.java:469)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.scout.rt.client.ModelContextProxy.lambda$1(ModelContextProxy.java:49)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:227)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxMandatory(TransactionProcessor.java:156)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxRequired(TransactionProcessor.java:139)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.intercept(TransactionProcessor.java:78)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:222)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain.call(CallableChain.java:170)
at org.eclipse.scout.rt.platform.context.RunContext.call(RunContext.java:158)
at org.eclipse.scout.rt.client.ModelContextProxy.lambda$0(ModelContextProxy.java:49)
at com.sun.proxy.$Proxy62.fireButtonClickFromUI(Unknown Source)
at org.eclipse.scout.rt.ui.html.json.form.fields.button.JsonButton.handleUiEvent(JsonButton.java:145)
at org.eclipse.scout.rt.ui.html.json.JsonEventProcessor.processEvent(JsonEventProcessor.java:52)
at org.eclipse.scout.rt.ui.html.json.JsonEventProcessor.processEvents(JsonEventProcessor.java:37)
The problem seems to be from the return line in both of the methods. This is line 61 of my ContactRestResourceClient.java class
Response.class);
I've read Chapter 17 REST of the Scout Technical Guide, but I still cannot solve the problem. Can anyone please help me figure out what I'm doing wrong?
JD
[Updated on: Fri, 05 August 2022 11:27] by Moderator
FUDForum. Page generated in 1.23406 seconds
