Can seem to Install or Run Eclipse [message #1853859] |
Wed, 20 July 2022 03:53  |
If i try to install it I get a message about an error log and if i download the package, extract it and run it i get the same message. this is the log file
!SESSION 2022-07-20 08:50:24.882 -----------------------------------------------
eclipse.buildId=4.20.0.I20210611-1600
java.version=16.0.1
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.osgi 4 0 2022-07-20 08:50:30.116
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: com/mercury/javashared/agentloader/AgentBootstrap
at org.eclipse.swt.widgets.Display.<init>(Display.java:557)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.java:742)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:168)
at org.eclipse.ui.internal.ide.application.IDEApplication.createDisplay(IDEApplication.java:182)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:125)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:78)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:654)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1462)
Caused by: java.lang.ClassNotFoundException: com.mercury.javashared.agentloader.AgentBootstrap cannot be found by org.eclipse.swt_3.116.100.v20210602-2209
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:519)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:170)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:519)
... 17 more
FUDForum. Page generated in 0.09027 seconds
