Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » 4DIAC Forte for Siemens device(Manipulate inputs and outputs on CPU 1515SP PC2 via 4DIAC Forte)
4DIAC Forte for Siemens device [message #1853813] Tue, 19 July 2022 00:14 Go to next message
I have recently used 4DIAC Forte for a raspberry pi, using the preset I/O modules in 4DIAC IDE. My question is if it is possible to create a 4DIAC Forte for the manipulation of inputs and outputs of a SIMATIC ET 200SP Open Controller CPU 1515SP PC2 of the Siemens brand.
Re: 4DIAC Forte for Siemens device [message #1853862 is a reply to message #1853813] Wed, 20 July 2022 05:57 Go to previous messageGo to next message
In short yes.
The long version is that to my current knowledge it is not as straight forward as on other platforms. The last time we experimented with this controller IO access was only possible via S7 part. But there was the possibility to have a shared memory communication between S7 part and any executable running in open controller part. The drawback is that both parts have to be fitting. So you need dedicated memory and function blocks on the s7 part and you need some special code on your application (e.g., 4diac FORTE). The good news is that Siemens provides templates for these which will get you started pretty quick.
Re: 4DIAC Forte for Siemens device [message #1853916 is a reply to message #1853862] Fri, 22 July 2022 10:10 Go to previous messageGo to next message
Excuse me and do you know if there are practical exercises based on the use of these templates, and could you help me with a guide.
Re: 4DIAC Forte for Siemens device [message #1853945 is a reply to message #1853916] Mon, 25 July 2022 06:42 Go to previous message
You can take a look at SIMATIC ODK 1500S .It provide pdf howto guideline and also template (https://support.industry.siemens.com/cs/document/106192387/simatic-odk-1500s-examples?dti=0&lc=en-AT )
Previous Topic:Deploy Applications Remotely in Two Devices
Next Topic:[SOLVED] Problem while installing ROS module on FORTE
Current Time: Sun Jul 20 04:34:12 EDT 2025
Powered by FUDForum. Page generated in 1.03617 seconds
