Home » Modeling » Papyrus » [C++ Code Build] Can the generated code be built with VCXX compiler?
[C++ Code Build] Can the generated code be built with VCXX compiler? [message #1853311] Mon, 27 June 2022 11:16 Go to next message
I would be interested to build the generated code with other compilers than gcc and particularly with VC tools.
Has someone done that with the generated code from a Papyrus model with Papyrus Software Designer? Is it even possible without modifying the code? The issue comes in particular from the use of rt and pthread libraries used for state machine code generation.
Any hint or help is welcome.
Regards.
Yoann.
Re: [C++ Code Build] Can the generated code be built with VCXX compiler? [message #1853395 is a reply to message #1853311] Thu, 30 June 2022 07:51 Go to previous message
Hi Yoann,
I haven't done that test yet. The state-machine code has only been tested/used with POSIX systems on my side. I think, the problem is not the compiler but rather the libraries coming by default in a VCxx context. Any experience from others?
Ansgar
Previous Topic:State of Papyrus compare in 2022
Next Topic:SysML model instantiation doubt
Current Time: Sat Jul 19 15:24:58 EDT 2025
Powered by FUDForum. Page generated in 0.03895 seconds
