Home » Modeling » OCL » OCLinEcore. How the set a attribute of type java.lang.Locale
OCLinEcore. How the set a attribute of type java.lang.Locale [message #1853236] Thu, 23 June 2022 13:27 Go to next message
I have an EMF Model like this:
class Text
attribute text : String[1];
attribute local : Locale[1];
datatype Locale : 'java.lang.Locale' { serializable };
It is possible to insert a string and convert it into java Locale Object in the dynamic instance(XMI)?
Re: OCLinEcore. How the set a attribute of type java.lang.Locale [message #1853255 is a reply to message #1853236] Fri, 24 June 2022 05:51 Go to previous messageGo to next message
Yes and No.
Part of the OCL test suite comprises:
		ocl.assertQueryTrue(null, "ecore::EDate{'2000-01-24'} <= ecore::EDate{value='2000-01-24'}");
so yes, string constructed data types are supported.
However the above uses Ecore's EDate mapping to java.util.Date and the custom implementation in EcoreFactoryImpl.createEDateFromString.
Locale has a single argument String constructor, so you may be lucky and find that Ecore's fallback to String works without any effort by you. More likely you will need to genmodel and manually implement createLocaleFromString to avoid the IllegalArgumentException at the end of EcoreFactoryImpl.createFromString.
That said, I must question the wisdom of using the non-String when the String would avoid problems.
Ed Willink
Re: OCLinEcore. How the set a attribute of type java.lang.Locale [message #1853267 is a reply to message #1853255] Fri, 24 June 2022 10:36 Go to previous message
Thanks for that hint. In the diagram there're two sections for custom code for an own DataType.
https://i.ibb.co/YX88Z0t/locale-ecore.png
[Updated on: Fri, 24 June 2022 10:37] by Moderator
Previous Topic:Check stereotype applications via static profile
Next Topic:Validation Delegate noy found
Current Time: Sun Jul 20 15:06:26 EDT 2025
Powered by FUDForum. Page generated in 0.06292 seconds
