Home » Eclipse Projects » Sirius » Validation of the odesign file fails
Validation of the odesign file fails [message #1852723] Thu, 02 June 2022 04:57 Go to next message
Hello everyone,
I have a problem with validating the design file. The error message says that the EClass used in domainClass is not accessible. However I have already added the dependency in the Manifest file and the correct metamodel is also selected in the properties tab (Metamodels). The application also runs without errors, but how I said, in the validation process the domain classes can not be found.
[Updated on: Thu, 02 June 2022 10:57] by Moderator
Re: Validation of the odesign file fails [message #1853146 is a reply to message #1852723] Mon, 20 June 2022 05:39 Go to previous message
I solved it! The problem was that the metamodel was not registered properly. I just added the VSP in a nested eclipse application
Previous Topic:invalid type literal exception in aql expression
Next Topic:add a listener to a diagram element
Current Time: Sun Jul 20 10:39:33 EDT 2025
Powered by FUDForum. Page generated in 0.05181 seconds
