Home » Archived » Jubula » Testing Javafx Properties(Is it possible to test a property within a Javafx control)
Testing Javafx Properties [message #1852546] Mon, 23 May 2022 05:43 Go to next message
Prior to version 8.5 it was possible to test the value of a property within a Javafx control. I used this to test a 'selected' property. I am using version 8.8 now and this shows that the ub_trt_checkPropertyAtMousePosition test is depreciated. What is the replacement for this?
Re: Testing Javafx Properties [message #1852547 is a reply to message #1852546] Mon, 23 May 2022 06:15 Go to previous messageGo to next message
I have found it under the unbound_modules_concrete/Check, the test ub_grc_checkProperty this works on standard properties but does not work with the SimplexxxxProperty if declared as public. What is the method to get user defined properties visible to Jubula?
[Updated on: Mon, 23 May 2022 07:52] by Moderator
Re: Testing Javafx Properties [message #1852549 is a reply to message #1852547] Mon, 23 May 2022 08:16 Go to previous messageGo to next message
Though I have created a property using the StringProperty class and made it visible to Scenic View by Jonathan Giles Jubula is still saying the Property is not available. What is the criteria for seeing user defined Javafx properties?
Re: Testing Javafx Properties [message #1852599 is a reply to message #1852549] Thu, 26 May 2022 09:12 Go to previous message
The trick is that the property must be created when the class is loaded, i.e. as a class variable and it must be initialized, (property=new Simple<type>Property(), not initialized when the object is created, i.e in the constructor.
Previous Topic:Selecting Panes
Next Topic:Cannot start AUT with Jubula 8.7.1.046
Current Time: Sun Jul 20 14:42:52 EDT 2025
Powered by FUDForum. Page generated in 0.85530 seconds
