Home » Eclipse Projects » Remote Application Platform (RAP) » /ui should work, but does not. But //ui does work?(Entry point is configured as '/ui, but does not work? //ui works)
/ui should work, but does not. But //ui does work? [message #1852019] Mon, 25 April 2022 20:33 Go to next message
I am new to RAP.
I use standalone (not OSGI) deployment with spring boot
The RWT servlet is registered as "/ui", but "/ui" does not work...
But somehow "//ui" works?
I use RWT 3.20.0-SNAPSHOT
What can be the reason of this double slash?
Gennady
Re: /ui should work, but does not. But //ui does work? [message #1852186 is a reply to message #1852019] Wed, 04 May 2022 08:01 Go to previous messageGo to next message
Hi Gennady,
I'm also running an RWT standalone setup on Spring Boot and I don't have issues with double slashes. However, it took me a while to find the correct programmatic setup to have the RWT components play well in Spring Boot, next to the default DispatcherServlet.
In order to further troubleshoot your issue, can you share some more code and config file, i.e. where you register the RWTServlet?
Ben
Re: /ui should work, but does not. But //ui does work? [message #1852207 is a reply to message #1852186] Wed, 04 May 2022 16:51 Go to previous message
Hi again,
I just create a small example project how to use RWT standalone on Spring Boot. Maybe it can help: https://www.eclipse.org/forums/index.php/t/1110729/
Ben
Previous Topic:Language of the browser
Next Topic:Example for RWT standalone on Spring Boot
Current Time: Sun Jul 20 16:48:59 EDT 2025
Powered by FUDForum. Page generated in 0.04134 seconds
