Home » Language IDEs » C / C++ IDE (CDT) » 32-bit libraries required.(Incompatibilty with 32-bit libraries trying to integrate another tool in the rmw implementation.)
32-bit libraries required. [message #1852138] Mon, 02 May 2022 03:45 Go to next message
I am trying to integrate V2X Unex with a DDS implementation, and my issue is that the DDS libs that I own are 64-bit and the V2X Unex libs for 32-bit.
Therefore, when I generate an executable, there are incompatibilities.
Using "-m32" flag, I cannot use DDS libs, using "-m64" flag I cannot use V2X Unex libs.
Are there any 32-bit libs that I can use? Where can I get them? How? Do you know any other solution to my issue?
Thank you very much in advance for your help.
I look forward to your response!
Re: 32-bit libraries required. [message #1852148 is a reply to message #1852138] Mon, 02 May 2022 13:17 Go to previous messageGo to next message
You are barking up a wrong tree here - there is nothing specific to Eclipse.
Please attempt to find V2X support.
Re: 32-bit libraries required. [message #1852162 is a reply to message #1852148] Tue, 03 May 2022 02:03 Go to previous message
I need Eclipse Cyclone DDS 32-bit libraries, if they exist.
Previous Topic:CDT Seems to look in wrong path for compile_commands.json
Next Topic:about how to package the cdt build result
Current Time: Sun Jul 20 08:43:38 EDT 2025
Powered by FUDForum. Page generated in 0.32314 seconds
