Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Question about event management in forte(How are events between function blocks managed and delivered?)
Question about event management in forte [message #1851998] Mon, 25 April 2022 09:05 Go to next message
Hi, 4diac team,
In the daily use of forte, I have some questions about how events are transferred and managed between function blocks? I read a lot of information and papers about IEC 61499. For a single function block, an event is actually an input with a value of 0 or 1. In the source code of forte, it may be "pa_nEIID".
However, how to realize the interaction of event flow between different function blocks, and the management and transmission of such events has always bothered me. I have seen the concepts of management model and event dispatcher in many places, but I haven't found the corresponding part in forte. Can you help me answer the relevant questions? Thank you.
Best wishes!
Re: Question about event management in forte [message #1852010 is a reply to message #1851998] Mon, 25 April 2022 14:40 Go to previous messageGo to next message
first of all an event is never a boolean. It is a trigger that an event occurred.
There are many different ways of implementing IEC 61499 runtimes. 4diac FORTE follows the approach described in the book "Real-time execution for IEC 61499" or my INDIN 2007 papers. The core class for managing the events is the EventChainExecutionThread.
I hope this helps.
Alois
Re: Question about event management in forte [message #1852022 is a reply to message #1852010] Tue, 26 April 2022 02:17 Go to previous messageGo to next message
Hi,Alois
Thank you for your answer, which is very important to me. I need to study the relevant contents of "event" again. Thank 4diac for providing such an experimental platform.
With regard to the "event flow", I hope to realize the trace variable and its associated events over a period of time, and better understand how "events" occur and manage when interacting between different function blocks.
Thanks!
Re: Question about event management in forte [message #1852024 is a reply to message #1852022] Tue, 26 April 2022 02:32 Go to previous messageGo to next message
happy to help.
This sounds very interesting. Would be interested to hear more about that when you have some results.
Alois
Re: Question about event management in forte [message #1852026 is a reply to message #1852024] Tue, 26 April 2022 05:42 Go to previous message
Hi,Alois
If there is progress, I will share the problems in the forum in time
Thanks!
Previous Topic:ID fields of the SUBSCRIBE/PUBLISH function blocks
Next Topic:4Diac Forte and Bacnet
Current Time: Sat Jul 19 16:33:42 EDT 2025
Powered by FUDForum. Page generated in 0.24077 seconds
