Unable to define multiple child creation extenders [message #1851949] |
Fri, 22 April 2022 10:07  |
Hello all,
I am unable to define multiple child creation extenders for my metamodel.
I can do so once, but not twice, no matter how simple the extension is.
Let me give the simplest example with 3 metamodels.
A = base, B/C = extenders.
In A I define classes 1,2,3, 1 owns a reference to a 2 and a 3
In metamodels B and C, after adding a dependency to metamodel A, I define respectively classes extending 2 and 3
In my editor I can create a model of type A with a root element of type 1, right click add child and I can see 2,3 and the class extending 3 but not the class extending 2. Its as if whatever project extends A last has precedence over whatever extensions others declare.
Note that in my example there should be no conflict as metamodels B and C extend classes 2 and 3, I don't see how this could happen, I saw some bug reports linked in similar posts but didn't understand how to manually fix the models as indicated.
I will attach a zip containing the 3 models, I tested on my end that I can generate All and run as eclipse application successfully and reproduce the issue, you should be able to create children of type NewEClass2, NewClass3 & Ext2 but not of type Ext.
I noticed some errors in console but don't know what to make of it.
!ENTRY org.eclipse.emf.ecore 2 0 2022-04-22 10:05:38.888
!MESSAGE Both 'A' and 'B' register a package for 'http://www.example.org/a'
!ENTRY org.eclipse.emf.ecore 2 0 2022-04-22 10:05:38.894
!MESSAGE Both 'B' and 'C' register a package for 'http://www.example.org/a'
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
!ENTRY org.eclipse.emf.ecore 2 0 2022-04-22 10:05:43.880
!MESSAGE a.impl.AFactoryImpl cannot be cast to a.AFactory
!STACK 0
java.lang.ClassCastException: a.impl.AFactoryImpl cannot be cast to a.AFactory
at a.impl.AFactoryImpl.init(AFactoryImpl.java:30)
[Updated on: Fri, 22 April 2022 10:07] by Moderator
Re: Unable to define multiple child creation extenders [message #1851952 is a reply to message #1851951] |
Fri, 22 April 2022 11:51  |
Thank you so much! I had no idea I could edit the genmodel to set the dependencies as references, it makes so much more sense now. I used to be able to extend the children without child extenders properties checked properly because the model was being copied and now it works as expected.
FUDForum. Page generated in 0.03854 seconds
