Home » Newcomers » Newcomers » no suitable driver found in jsp but not as java application
no suitable driver found in jsp but not as java application [message #1851223] Thu, 31 March 2022 04:02 Go to next message
I am using JSP for the first time and trying to do a web application.The problem I'm facing is that the Database connection works great if run from the App.java class, but if I run it from the JSP file it will throw a SQLException saying it didn't find a suitable driver. I put the driver in the server's classpath, in the WEB-INF/lib, in the project's build path as external JAR.
environment:
Microsoft SQL Server 2017,
sqljdbc_10.2/mssql-jdbc-10.2.0.jre11.jar
server:Tomcat v10.0.13
eclipse java ee ide
Error message:
Mar 31, 2022 10:43:57 ÖÖ org.apache.catalina.startup.VersionLoggerListener log
INFO: Server version name: Apache Tomcat/10.0.13
INFO: Server built: Nov 9 2021 22:12:58 UTC
INFO: Server version number: 10.0.13.0
INFO: OS Name: Windows 10
INFO: OS Version: 10.0
INFO: Architecture: amd64
INFO: Java Home: C:\Users\kirla\.p2\pool\plugins\org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_17.0.0.v20211012-1059\jre
INFO: JVM Version: 17+35
INFO: JVM Vendor: Eclipse Adoptium
INFO: CATALINA_BASE: C:\Users\kirla\eclipse-workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp1
INFO: CATALINA_HOME: C:\Users\kirla\Downloads\apache-tomcat-10.0.13
INFO: Command line argument: -Dcatalina.base=C:\Users\kirla\eclipse-workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp1
INFO: Command line argument: -Dcatalina.home=C:\Users\kirla\Downloads\apache-tomcat-10.0.13
INFO: Command line argument: -Dwtp.deploy=C:\Users\kirla\eclipse-workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp1\wtpwebapps
INFO: Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED
INFO: Command line argument: --add-opens=java.base/java.io=ALL-UNNAMED
INFO: Command line argument: --add-opens=java.base/java.util=ALL-UNNAMED
INFO: Command line argument: --add-opens=java.base/java.util.concurrent=ALL-UNNAMED
INFO: Command line argument: --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
INFO: Command line argument: -Dfile.encoding=Cp1254
INFO: Command line argument: -XX:+ShowCodeDetailsInExceptionMessages
Mar 31, 2022 10:43:57 ÖÖ org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [C:\Users\kirla\.p2\pool\plugins\org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_17.0.0.v20211012-1059\jre\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Users/kirla/eclipse//plugins/org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_17.0.2.v20220201-1208/jre/bin/server;C:/Users/kirla/eclipse//plugins/org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_17.0.2.v20220201-1208/jre/bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\150\Tools\Binn\;C:\Program Files\Microsoft SQL Server\150\Tools\Binn\;C:\Program Files\Microsoft SQL Server\150\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\150\DTS\Binn\;C:\Program Files\dotnet\;C:\Users\kirla\AppData\Local\Microsoft\WindowsApps;C:\Program Files\Azure Data Studio\bin;C:\Users\kirla\AppData\Local\GitHubDesktop\bin;C:\Users\kirla\AppData\Local\Programs\Microsoft VS Code\bin;C:\Program Files (x86)\Brackets\;C:\Users\kirla\.dotnet\tools;C:\Users\kirla\eclipse;;.]
Mar 31, 2022 10:43:58 ÖÖ org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-nio-8080"]
Mar 31, 2022 10:43:58 ÖÖ org.apache.catalina.startup.Catalina load
INFO: Server initialization in [1261] milliseconds
Mar 31, 2022 10:43:58 ÖÖ org.apache.catalina.core.StandardService startInternal
INFO: Starting service [Catalina]
Mar 31, 2022 10:43:58 ÖÖ org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet engine: [Apache Tomcat/10.0.13]
Mar 31, 2022 10:43:59 ÖÖ org.apache.jasper.servlet.TldScanner scanJars
INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
Mar 31, 2022 10:43:59 ÖÖ org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-nio-8080"]
Mar 31, 2022 10:43:59 ÖÖ org.apache.catalina.startup.Catalina start
INFO: Server startup in [1139] milliseconds
oopss
java.sql.SQLException: No suitable driver found for jdbc:sqlserver://DESKTOP-EFD0KAH:1433;DatabaseName=Blog;encrypt=true;trustServerCertificate=true
at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:706)
at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:229)
at Controller.DBConnection.connDb(DBConnection.java:23)
at Controller.BlogController.<init>(BlogController.java:14)
at org.apache.jsp.View.cevap_jsp._jspService(cevap_jsp.java:133)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at jakarta.servlet.http.HttpServlet.service(HttpServlet.java:777)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:466)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:380)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:328)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:223)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:158)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:185)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:197)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:541)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:119)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:690)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:353)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:382)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:872)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1695)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:833)
Mar 31, 2022 10:44:00 ÖÖ org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet [jsp] in context with path [/WebApplication] threw exception [An exception occurred processing [View/cevap.jsp] at line [50]
47: <div class="col-10">
48: <%
49:
50: List<BlogModel> list=ozelBlog.getBlogList();
51:
52: for(BlogModel blog:list){
53:
Stacktrace:] with root cause
java.lang.NullPointerException: Cannot invoke "java.sql.Connection.createStatement()" because "this.conn" is null
at Controller.BlogController.getBlogList(BlogController.java:23)
at org.apache.jsp.View.cevap_jsp._jspService(cevap_jsp.java:176)
Here is my Java codes.
DBConnection.java
package Controller;
import java.sql.*;
public class DBConnection {
	public Connection con = null;
	public String host = "localhost";
	public String serverName = "DESKTOP-EFD0KAH";
	public int port = 1433;
	public String dbName = "Blog";
	public String properties = "encrypt=true;trustServerCertificate=true";
	//public String url = "jdbc:sqlserver://DESKTOP-EFD0KAH:1433;DatabaseName= Hospital ;encrypt=true;trustServerCertificate=true";
	public String url = "jdbc:sqlserver://"+serverName+":"+port+";DatabaseName="+dbName+";"+properties;
	public String user="sa";
	public String password="123";
	public DBConnection() {}
	public Connection connDb() {
		try {
			this.con = DriverManager.getConnection(url,user,password);
			System.out.println("connected.");
			return con;
		} catch (SQLException e) {
			System.out.println("oopss");
			e.printStackTrace();
		return con;
BlogController.java
package Controller;
import java.sql.Connection;
import java.sql.PreparedStatement;
import java.sql.ResultSet;
import java.sql.Statement;
import java.sql.SQLException;
import java.util.ArrayList;
import Model.BlogModel;
public class BlogController extends DBConnection {
	DBConnection con = new DBConnection();
	Connection conn = con.connDb();
	Statement st = null;
	ResultSet rs = null;
	public ArrayList<BlogModel> getBlogList() throws SQLException {
		ArrayList<BlogModel> list = new ArrayList<>();
		BlogModel post;
		try {
			String sorgu = "SELECT * FROM post";
			st = conn.createStatement();
			rs = st.executeQuery(sorgu);
			while (rs.next()) {
				post = new BlogModel(rs.getInt("id"), rs.getString("title"), rs.getString("body"),
						rs.getString("createdAt"), rs.getInt("published"));
				list.add(post);
		return list;
and the index.jsp
<%@page import="org.apache.coyote.ContinueResponseTiming"%>
<%@ page language="java" contentType="text/html; charset=ISO-8859-1"
	pageEncoding="ISO-8859-1"%>
<%@page import="Controller.BlogController,Model.BlogModel,java.util.*,java.sql.*"%>
	BlogController ozelBlog = new BlogController();
<!DOCTYPE html>
<html>
<head>
<meta charset="UTF-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<link
	href="htstss"
	rel="stylesheet"
	integrity="sha384-1BmE4kWBq78iYhFldvKuhfTAU6auU8tT94WrHftjDbrCEXSU1oBoqyl2QvZ6jIW3"
	crossorigin="anonymous">
<link rel="stylesheet"
	href="hare.()/ajamin.css"
	integrity="sha512-9usAa10IRO0HhoUiKdWk5t3PyolY1cOd4DSE0Ga+ri4AuTroPR5aQvXU9xC6qOPnzFeg=="
	crossorigin="anonymous" referrerpolicy="no-referrer" />
<link rel="preconnect" href="hts.( those are link)">
<link rel="preconnect" href="htatic." crossorigin>
<link
	href="htss2?fa=swap"
	rel="stylesheet">
<link rel="stylesheet" href="style.css">
<title>Awesome Blog</title>
</head>
<body>
	<main>
		<div class="bg-dark px-4 py-5 text-center text-white">
			<div class="container my-4">
				<div class="latest">
					<p>Latest posts...</p>
				</div>
				<div class="card-group text-dark">
					<div class=" row"
						style="width: 100%; background-image: url(../img/thumb-1920-190787.jpg)">
						<div class="col-2"></div>
							<div class="card m-5">
								<img class="card-img-top" src="img/1.jpeg" alt="Card image cap">
								<div class="card-body">
									<h5 class="card-title">
										blog.getTitle();
									</h5>
									<p class="card-text">
										blog.getBody();
									</p>
								</div>
								<div class="card-footer">
									<small class="text-muted">
										blog.getCreatedAt();
									</small>
								</div>
							</div>
						</div>
					</div>
				</div>
			</div>
		</div>
	</main>
</body>
</html>
index.php/fa/41837/0/
Thanks.
Re: no suitable driver found in jsp but not as java application [message #1851238 is a reply to message #1851223] Thu, 31 March 2022 10:13 Go to previous message
"I put the driver in the server's classpath, in the WEB-INF/lib, in the project's build path as external JAR."
Which one is it? And are you sure it doesn't require any native DLLs?
[Updated on: Thu, 31 March 2022 13:10] by Moderator
Previous Topic:Developer Issue with eclipse Neon IDE delivering log4j 1.2.15 version which is vulnerability
Next Topic:Toggle line comment in Javascript file
Current Time: Sun Jul 20 06:26:36 EDT 2025
Powered by FUDForum. Page generated in 0.07022 seconds
