Home » Language IDEs » C / C++ IDE (CDT) » Compiling C and C++ code in the same project(Combining C and C++)
Compiling C and C++ code in the same project [message #1850386] Mon, 28 February 2022 15:56 Go to next message
Does anyone know how to create a project where the compiler compiles c source files with GCC and C++ source files with g++? I don't really need to do it this way. All I'm trying to achieve is to have the main c file (main.c) that calls functions from other files whether they are c or c++ source files. For example, I would like to be able to include a header from a c++ source file so in my int main() I can call add(2,3) and the output would be 5 (the add function would exist in a c++ source file). However, when I try using g++ to compile the entire project, there are many build errors in the c source files. When I try using GCC to compile the project, the c++ source files are ignored. I would love to be able to convert an existing project to be compatible with both c and c++ but I'm also open to creating a new project from scratch to do this as long as I can work with both C and C++. Just in case this matters, I wanted to mention that I am using Eclipse CDT on Xilinx SDK. Thanks!
Re: Compiling C and C++ code in the same project [message #1850409 is a reply to message #1850386] Wed, 02 March 2022 00:00 Go to previous messageGo to next message
Just add them to your source file directory.
If you are using Managed Build, make will sort them out.
Re: Compiling C and C++ code in the same project [message #1850488 is a reply to message #1850409] Fri, 04 March 2022 12:25 Go to previous messageGo to next message
I tried doing that but did not get any luck with it. What ended up working was changing the compiler commands (under properties) for the C files from g++ to gcc. Thank you for your reply!
Re: Compiling C and C++ code in the same project [message #1850493 is a reply to message #1850488] Fri, 04 March 2022 22:02 Go to previous message
g++ was the compiler for C files? Odd. The default is gcc.
Previous Topic:where and how to tell eclipse to add something to moc?
Next Topic:StackOverFlowerror Recursive ProgressMonitorWrapper
Current Time: Sun Jul 20 15:52:09 EDT 2025
Powered by FUDForum. Page generated in 0.14057 seconds
