Home » Eclipse Projects » Eclipse Titan » Serial-Port "hex-mode"(Interpreting the data send via serial port as octetstring)
Serial-Port "hex-mode" [message #1850402] Tue, 01 March 2022 10:32 Go to next message
I want to communicate to a device using its serial interface. Manually I can communicate using "hex-mode" for input and output data, for example using CuteCom.
A command might look like: A50004FFFB070004043F34
Using Titan, I am using the serial port from gitlab, which only accepts a CHARSTRING.
Simply converting from the OCTETSTRING above (A50004FFFB070004043F34) to CHARSTRING doesnt work since characters are not in the allowed range (00..7F),
and converting using oct2str does not work either.
How can I send data via the serial port, where the content in the CHARSTRING is directly interpreted as Bytes?
BR
Re: Serial-Port "hex-mode" [message #1850413 is a reply to message #1850402] Wed, 02 March 2022 02:40 Go to previous messageGo to next message
The current version of the test port doesn't support binary data, but it can be updated easily.
Re: Serial-Port "hex-mode" [message #1850419 is a reply to message #1850413] Wed, 02 March 2022 06:58 Go to previous message
Thank you for your fast reply.
I extended the testport by adding an additional parameter (binary_mode) to the testport and then do the the conversion if needed in the outgoing and incoming functions of the testport.
[Updated on: Wed, 09 March 2022 09:55] by Moderator
Previous Topic:How to find memory leaks using MEMORY_DEBUG
Next Topic:Encode/Decode enable for all ttcn modules
Current Time: Sun Jul 20 16:06:27 EDT 2025
Powered by FUDForum. Page generated in 0.03428 seconds
