Home » Modeling » EMF Parsley » context menu (delete option)(How to control delete option depending user role)
context menu (delete option) [message #1850144] Thu, 17 February 2022 16:55 Go to next message
I m trying to modify a running EMF Parlsey application and control the "delete" option on the context menu. (Rigth click : see image in copy)
I m searching how to show this "delete" option only if user has a role but i don t know were it could be control.
Any idea will be great.
thanks
Oliver
Re: context menu (delete option) [message #1850153 is a reply to message #1850144] Fri, 18 February 2022 03:54 Go to previous messageGo to next message
As far as I remember, you have to handle the generation of context menus manually: for the moment you cannot simply disable a default context menu, you have to create all the items in the context menu of a given object
Re: context menu (delete option) [message #1850163 is a reply to message #1850153] Fri, 18 February 2022 10:03 Go to previous messageGo to next message
Hi here the solution finded.
Maybe will be util for someone.
In view.parsley -> section menuBuilder
menuBuilder {
		menus {
			ObjectTypeToReplace -> #[
				separator
Re: context menu (delete option) [message #1850171 is a reply to message #1850163] Sat, 19 February 2022 03:54 Go to previous message
Exactly! Thanks for sharing :)
Previous Topic:ChangeRecorder cannot be found by org.eclipse.emf.edit
Next Topic:Customize default SaveableTreeView edit action
Current Time: Sat Jul 19 18:14:43 EDT 2025
Powered by FUDForum. Page generated in 0.04337 seconds
