Home » Eclipse Projects » Eclipse Scout » ModelJobs not working when focus is out
ModelJobs not working when focus is out [message #1850021] Fri, 11 February 2022 04:08 Go to next message
I have created ModelJob to run some job (fetch location using requestGeolocation() method) in Desktop.java in execInit method. (Also tried in execOpened and execGuiAttached).
This is working ok, if application is active and focused. But job stops working when:
1. We open another tab in browser
2. When we minimize browser
3. When we open another browser with another page
Is it possible to always run job to requestGeolocation even if application is out of focus.
This is code for ModelJob:
ModelJobs.schedule(() -> {
findLocationForTeam();
}, ModelJobs.newInput(ClientRunContexts.copyCurrent())
.withExecutionTrigger(Jobs.newExecutionTrigger().
withStartIn(5,TimeUnit.SECONDS)
.withSchedule(FixedDelayScheduleBuilder.repeatForever(10, TimeUnit.SECONDS)))
					.withExceptionHandling(new ExceptionHandler() {
						public void handle(Throwable t) {
							System.err.println("Error with JOB: " + t);
}, true));
I also tried to set property isTrackFocus on Desktop.java to false, but have same problem.
Thank you!
Re: ModelJobs not working when focus is out [message #1850023 is a reply to message #1850021] Fri, 11 February 2022 04:26 Go to previous messageGo to next message
I think I solved it. It is Jobs.schedule, not ModelJobs
Re: ModelJobs not working when focus is out [message #1850025 is a reply to message #1850023] Fri, 11 February 2022 05:17 Go to previous messageGo to next message
Not working. I have error that only ModelJobs can update UI model.
Can someone help me?
Thank you
Re: ModelJobs not working when focus is out [message #1850033 is a reply to message #1850025] Fri, 11 February 2022 10:41 Go to previous message
Hi Luka
The whole geolocation magic happens in the JS part of the application. The Java part in Desktop.java only sends an event to the browser, which results in a call to the "navigator.geolocation" API and returns the results in a JSON response. You should see that request/reponse when you open the network panel (F12) an look at the JSON requests.
I did not test it but I can imagine, that the browser does not respond to calls to the geolocation API when the browser tab/window is not active - it would make sense, because you don't want a malicious website to access your location in the background. You might need to debug into DesktopAdapter.js#_onRequestGeolocation to see what happens in your case.
I'd recommend to check first if the geolocation API responds to calls when the browser is in the background, in a plain HTML/JavaScript environment for instance with https://jsfiddle.net/.
Cheers
André
Previous Topic:22.0-beta1: Classic App not loading after successful login
Next Topic:How to add Content Security Policy frame-ancestors?
Current Time: Sun Jul 20 16:12:27 EDT 2025
Powered by FUDForum. Page generated in 0.04036 seconds
