Home » Modeling » EMF » Suspected inconsistencies in URIHandler.exist
Suspected inconsistencies in URIHandler.exist [message #1849829] Thu, 03 February 2022 11:50 Go to next message
when we tried to decouple our code from concrete file system implementations (java.io, org.eclipse.core.resources), we thought it might be a great idea to base most of the IO work on the abstraction of URIs and URIConverter.
After all, URIConverter offers almost everything one needs to work with resources.
When we were testing this in an Eclipse environment that also uses virtual folders, we figured some inconsistencies between the PlatformResourceURIHandlerImpl and FileURIHandlerImpl.
The FileURIHandlerImpl will happily answer a query for exists() with true, if it refers to a directory, whereas the PlatformResourceURIHandlerImpl doesn't agree to that for virtual folders. It resorts to the WorkbenchHelper
    public static boolean exists(String platformResourcePath, Map<?, ?> options)
      IResource resource = getWorkspaceRoot().findMember(new Path(platformResourcePath));
      return resource != null && resource.getResourceAttributes() != null;
Is there a reason why this isn't implemented by means of `resource.exists()` but rejects virtual resources?
Re: Suspected inconsistencies in URIHandler.exist [message #1849841 is a reply to message #1849829] Fri, 04 February 2022 03:07 Go to previous messageGo to next message
Is the problem that's it's null because the resource is not local? I'm not sure what virtual means and I see that org.eclipse.core.resources.IResource.isLocal(int) is deprecated without replacement.
What do you think should be changed? Use org.eclipse.core.resources.IResource.isAccessible()?
Re: Suspected inconsistencies in URIHandler.exist [message #1849845 is a reply to message #1849841] Fri, 04 February 2022 04:34 Go to previous messageGo to next message
Hi Ed,
thank you for the quick feedback. I'd think that `IResource.isAccessible()` would indeed be a proper replacement and would be in line with what I'd expect the URIConverter to respond to exists().
We'll probably do some experiments with a locally patched ExtendURIConverter with a replaced specialization of the PlatformResourceURIHandlerImpl. I'll report back here.
Best
Sebastian
Re: Suspected inconsistencies in URIHandler.exist [message #1849852 is a reply to message #1849845] Fri, 04 February 2022 11:23 Go to previous messageGo to next message
Rather than patching EMF, you can install your own 'better' URIHandler in front of / instead of the standard in ExtensibleURIConverterImpl.getContentHandlers.
Ed Willink
Re: Suspected inconsistencies in URIHandler.exist [message #1849883 is a reply to message #1849852] Mon, 07 February 2022 07:13 Go to previous message
Hi Ed,
yes, that's what I meant by locally patched.
Best
Sebastian
Previous Topic:[CDO] Rare problem in permission cache
Next Topic:how to make a ComboView not selectable
Current Time: Sun Jul 20 14:43:14 EDT 2025
Powered by FUDForum. Page generated in 0.04001 seconds
