Home » Modeling » EMF » [CDO] Rare problem in permission cache(NoPermissionException when modifying a writable object)
[CDO] Rare problem in permission cache [message #1849800] Thu, 03 February 2022 05:04 Go to next message
This issue kept us busy for some time and we could never figure out where it is coming from. But now I can somewhat reproduce it on our system.
Problem description:
We continuously add objects to a list (which is the content of a cdo object). We keep the list in a reasonable size of ~1000 obejcts.
Quite rarely, but randomly (it takes ~0 to 1000k commits), one of the objects in the list will have the permission to be read-only. This is tied to the session. Even if we open a new transaction, the permission will stay read-only. For new sessions, the permission is correct again.
Now I am able to reproduce this on our system. I tested the 2021-09 release with H2 db and TCP/JVM/WS connection, non-branching, non-auditing. What I do:
* Add new objects to a list in one thread.
* In another thread: open a view and add an EContentAdapter to the object that holds the list and wait for 1 second. Then close the view again and repeat.
I attached my console output with full cdo tracing enabled. See end for the NoPermissionException. Maybe we can find a workaround to recover the correct permission? Or is this log even enough to hint to a fix?
[Updated on: Thu, 03 February 2022 05:25] by Moderator
Re: [CDO] Rare problem in permission cache [message #1849806 is a reply to message #1849800] Thu, 03 February 2022 06:18 Go to previous messageGo to next message
I created another debug log with the most recent release (20220116-1034). This time additionally with net4j tracing enabled.
What I noticed: we seem to always get another exception beforehand "java.lang.UnsupportedOperationException: Mapping strategy does not support audits"
Re: [CDO] Rare problem in permission cache [message #1849807 is a reply to message #1849800] Thu, 03 February 2022 06:21 Go to previous messageGo to next message
Hi Robert,
Thanks for trying to reproduce the problem.
Do you think you can come up with a CDO test case, so that I can reproduce it, too?
Here's a list of existing test cases that use and test a security manager:
Bugzilla_417483_Test.doSetUp()
Bugzilla_399487_Test.setUp()
Bugzilla_422170_Test.setUp()
Bugzilla_501607_Test.setUp()
Bugzilla_560280_Test.setUp()
Bugzilla_418267_Test.startSecureRepository()
Re: [CDO] Rare problem in permission cache [message #1849816 is a reply to message #1849807] Thu, 03 February 2022 09:48 Go to previous messageGo to next message
Sorry, I missed your second message. Do you have the CDO sources at hand in order to try something out?
In CommitTransactionIndication.java at line 410 you see this:
CDOBranchPoint securityContext = commitContext.getBranchPoint();
Please change that line to the following:
if (!session.getManager().getRepository().isSupportingAudits())
     securityContext = securityContext.getBranch().getHead();
Does that fix the problem?
Re: [CDO] Rare problem in permission cache [message #1849819 is a reply to message #1849807] Thu, 03 February 2022 10:06 Go to previous messageGo to next message
Hi Eike, please see the attached patch which reproduces the problem for me quite reliably. You need to start the test case in non-audit mode.
Its a bit messy ("Logspec" package was copied from our code), sorry for that ;).
[Updated on: Thu, 03 February 2022 10:06] by Moderator
Re: [CDO] Rare problem in permission cache [message #1849820 is a reply to message #1849819] Thu, 03 February 2022 10:10 Go to previous messageGo to next message
Great!! Your proposed fix seems to work!
Just out of curiosity: why is this so hard to reproduce?
Re: [CDO] Rare problem in permission cache [message #1849834 is a reply to message #1849820] Thu, 03 February 2022 23:56 Go to previous messageGo to next message
Thanks for the verification. Please submit a bugzilla.
Re: [CDO] Rare problem in permission cache [message #1849839 is a reply to message #1849834] Fri, 04 February 2022 02:54 Go to previous message
I created this ticket:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=578577
Previous Topic:Short Survey About Requirements Engineering
Next Topic:Suspected inconsistencies in URIHandler.exist
Current Time: Sun Jul 20 08:37:52 EDT 2025
Powered by FUDForum. Page generated in 0.04567 seconds
