Home » Eclipse Projects » GEF » Non-moveable edit parts
Non-moveable edit parts [message #184941] Tue, 21 June 2005 04:56 Go to next message
Originally posted by: sidney.lee.ibs.net
Hi!
How do I make an child part completely stationary with any attempt to
move it having no effect, no ghost rectangle, etc.
What I have done thus far is have the edit policy for the parent
implement createChildEditPolicy(EditPart) to return the
NonResizableEditPolicy with setDragAllowed(false). I selected the object
and when I try to move it (hoping it would remain stationary), I get the
exception posted below (P.S. I find it odd that dragging is being
handled when I have explicitly asked that it not be):
Any suggestions?
Many Thanks!
at
org.eclipse.gef.tools.DragEditPartsTracker.updateTargetReque st(DragEditPartsTracker.java:593)
at
org.eclipse.gef.tools.DragEditPartsTracker.handleDragInProgr ess(DragEditPartsTracker.java:333)
at org.eclipse.gef.tools.AbstractTool.mouseDrag(AbstractTool.ja va:994)
at org.eclipse.gef.tools.SelectionTool.mouseDrag(SelectionTool. java:511)
at org.eclipse.gef.EditDomain.mouseDrag(EditDomain.java:212)
at
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Moved(DomainEventDispatcher.java:342)
at
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseMove( LightweightSystem.java:523)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:144)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Re: Non-moveable edit parts [message #184949 is a reply to message #184941] Tue, 21 June 2005 05:12 Go to previous messageGo to next message
Sidney Lee wrote:
> Hi!
> Any suggestions?
> Many Thanks!
> at
> at
> at
> at
> at
> at
> at
> at
> at
I'm working on a similar problem. I've subclassed ResizableEditPolicy. In
it's constructor have:
public MyChildSelectionEditPolicy() {
setResizeDirections(0);
setDragAllowed(false);
The policy is installed on the child edit part as:
installEditPolicy(EditPolicy.PRIMARY_DRAG_ROLE,
new ParentSelectionEditPolicy());
You should now be able to select the child. It will have corner resize
handles but attempts to resize or drag will fail. It dosen't seem to matter
what policies are installed on the parent.
Cheers, Steve.
Re: Non-moveable edit parts [message #184980 is a reply to message #184949] Tue, 21 June 2005 07:22 Go to previous messageGo to next message
thanks, but that seems to have had no effect... :(
Steve Jones wrote:
> Sidney Lee wrote:
>>Hi!
>>Any suggestions?
>>Many Thanks!
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> Cheers, Steve.
non-moveable edit part - a solution ??? [message #185013 is a reply to message #184949] Tue, 21 June 2005 12:49 Go to previous messageGo to next message
well, solved the problem - here was what I had to do:
(i) I subclassed NonResizableEditPolicy as follows:
public MyNonResizableEditPolicy(){
super();
setDragAllowed (false);
(ii) I used the parents layout policy to install it as follows:
protected EditPolicy createChildEditPolicy(EditPart child) {
return new MyNonResizableEditPolicy();
( amounts to the same as being installed on the child edit part as:
new MyNonResizableEditPolicy()); )
(iii) but there seems to be a problem with the dragTracker, which I
solved in my non-moveable EditPart class by returning the
SelectEditPartTracker (as oppose to the DragEditPartsTracker) in
getDragTracker(Request)
is this last step really necessary?
(I did override createSelectionHandles() in the MyNonResizableEditPolicy
to return Collections.EMPTY_LIST as I didn't want the part decorated --
but even if I did not do so, the problem persisted. The GEF
NonResizableEditPolicy does seem to use the SelectEditPartTracker...
something seems to be going wrong somewhere)
Re: non-moveable edit part - a solution ??? [message #185089 is a reply to message #185013] Wed, 22 June 2005 09:49 Go to previous message
> super(); setDragAllowed (false);
That's a public method. Couldn't you have also just called it after
instantiating?
> (iii) but there seems to be a problem with the dragTracker, which I solved
> in my non-moveable EditPart class by returning the SelectEditPartTracker
> (as oppose to the DragEditPartsTracker) in getDragTracker(Request)
Previous Topic:Is there a reliable converter bewteen draw2d.Graphics and awt.Graphics2D?
Next Topic:Problems implementing a layout
Current Time: Sat Jul 19 15:26:38 EDT 2025
Powered by FUDForum. Page generated in 0.04202 seconds
