MQTTSNGateway in docker container [message #1848573] |
Wed, 08 December 2021 06:29 |
I am trying to build Paho MQTT SN Gateway for arm64/v8 in docker container with alpine 3.14 build environment. I don't get any errors while building the image. But on loading inside the container, the MQTT-SNGateway image failing with symbol not found errors as shown below . It looks like the MQTTSNPacket shared library in not linked with the image? Can you please help me in understanding and correcting this? I find that on my host machine, MQTT-SNGateway created with exact build process executed well. Thanks for the support!
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNKSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE4dataEv: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNSerialize_willmsgreq: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNKSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE4sizeEv: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNSerialize_register: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZSt19__throw_logic_errorPKc: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNSerialize_pubcomp: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNSt9exceptionD2Ev: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNPacket_name: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE6insertEmRKS4_: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNSaIcED1Ev: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEaSERKS4_: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE10_M_disposeEv: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNSerialize_unsuback: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNKSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE4findEcm: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: writeMQTTSNString: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNDeserialize_regack: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNKSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE6lengthEv: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNSerialize_gwinfo: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEaSEOS4_: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE13_M_set_lengthEm: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNKSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE8capacityEv: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNSerialize_advertise: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNKSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE6substrEmm: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNSerialize_willtopicresp: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNKSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE12find_last_ofEPKcm: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNSerialize_pubrec: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNSerialize_disconnect: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE13_M_local_dataEv: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: __cxa_rethrow: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _Unwind_Resume: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNSerialize_connack: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNDeserialize_willmsg: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE6appendEPKc: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEC1EPKcRKS3_: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNSerialize_regack: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: MQTTSNSerialize_willtopicreq: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZTVN10__cxxabiv120__si_class_type_infoE: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZTVN10__cxxabiv117__class_type_infoE: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZTISt9exception: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZTVN10__cxxabiv121__vmi_class_type_infoE: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZTVSt9exception: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: _ZTIb: symbol not found
Error relocating ./usr/bin/MQTTSNGateway/bin/MQTT-SNGateway: __gxx_personality_v0: symbol not found
and so on ..........
FUDForum. Page generated in 0.24432 seconds
