Home » Eclipse Projects » Eclipse Titan » Compiler core dump on Linux and Windows(TITAN Compiler ASN.1)
Compiler core dump on Linux and Windows [message #1844967] Fri, 01 October 2021 04:22 Go to next message
I got a compiler core dump while compiling last versions of ETSI PKI, IEEE 1609.2 and 1609.2.1 ASN files.
I created a small project based on Hello demo with all these ASN.1 files (see attached file).
Just execute 'make check' to get the core dump.
My compiler version is:
TTCN-3 and ASN.1 Compiler for the TTCN-3 Test Executor
Version: 8.0.0
Build date: Jul 23 2021 09:26:26
Compiled with: GCC 9.4.0
Using OpenSSL 1.1.1g 21 Apr 2020
Commit id: 50f4bb3c3
Copyright (c) 2000-2021 Ericsson Telecom AB
Many thanks for your help,
BR\Yann
Re: Compiler core dump on Linux and Windows [message #1844969 is a reply to message #1844967] Fri, 01 October 2021 05:31 Go to previous messageGo to next message
Hi Yann,
We are investigating it, will let You know the result ASAP.
Lenard
Re: Compiler core dump on Linux and Windows [message #1847654 is a reply to message #1844969] Wed, 03 November 2021 02:20 Go to previous messageGo to next message
Hello Lenard,
Do you have any news?
Thanks a lot,
BR\ Yann
[Updated on: Wed, 03 November 2021 02:20] by Moderator
Re: Compiler core dump on Linux and Windows [message #1847750 is a reply to message #1847654] Fri, 05 November 2021 07:48 Go to previous messageGo to next message
Hi Yann,
We have some achievements. The crash is gone in the latest codebase, but there are false negative errors still.
Here You can follow the progress:
https://gitlab.eclipse.org/eclipse/titan/titan.core/-/issues/573
If You have the time please build Titan from the latest code and let us now if You have any comments.
Lenard
Re: Compiler core dump on Linux and Windows [message #1847790 is a reply to message #1847750] Mon, 08 November 2021 08:44 Go to previous messageGo to next message
Hello Lenard,
Thanks a lot, I'll come back to you soon ;)
BR\Yann
Re: Compiler core dump on Linux and Windows [message #1847949 is a reply to message #1847790] Mon, 15 November 2021 02:36 Go to previous messageGo to next message
Hello Lenard,
I did some test with the latest version from GITLAB, and I got strange errors using the sample MyExample-211001-1017.tgz I provided in my first message.
These errors are about circular reference:
Ieee1609Dot2Dot1Protocol.asn:255: error: While checking circular type references in subtype definitions: Circular reference: `' -> `@Ieee1609Dot2Dot1Protocol.SignerSingleCert' -> `'
To be honest, I don't understand the reasons of these errors.
Thanks a lot for your support,
BR\Yann
Re: Compiler core dump on Linux and Windows [message #1848474 is a reply to message #1847949] Fri, 03 December 2021 06:46 Go to previous messageGo to next message
Hi Yann,
This error has been fixed in the latest source code, please give it a try.
Lenard
Re: Compiler core dump on Linux and Windows [message #1848608 is a reply to message #1848474] Thu, 09 December 2021 10:59 Go to previous message
Hello Lenard,
It works fine now.
Yann
Previous Topic:TTCN-3 record with a field of type "port"
Next Topic:Strategies for shutting down complex component hierarchy
Current Time: Sun Jul 20 14:27:11 EDT 2025
Powered by FUDForum. Page generated in 0.23931 seconds
