Home » Newcomers » Newcomers » Eclipse will not restart after package installation(Installation of scala appears to have broken eclipse?)
Eclipse will not restart after package installation [message #1847980] Tue, 16 November 2021 00:04 Go to next message
After installing the scala package, eclipse is refusing to start. I have no idea what's broken, can someone offer some suggestions?
Here is the last session trace from .metadata/.log:
!SESSION 2021-11-16 15:28:33.685 -----------------------------------------------
eclipse.buildId=4.21.0.I20210906-0500
java.version=17
java.vendor=Eclipse Adoptium
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_AU
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.oomph.p2.core 2 0 2021-11-16 15:28:38.933
!MESSAGE Failed to register the thread safe credentials providers: 'java.util.Map org.eclipse.core.internal.runtime.AdapterManager.getFactories()'
!ENTRY org.eclipse.osgi 4 0 2021-11-16 15:28:41.414
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (127).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:828)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:759)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1019)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:365)
at org.eclipse.osgi.container.Module.doStart(Module.java:605)
at org.eclipse.osgi.container.Module.start(Module.java:468)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:404)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:117)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:572)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:345)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:388)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:41)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:463)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:170)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:520)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:153)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
Caused by: org.aspectj.weaver.BCException: Unable to find Asm for stackmap generation (Looking for 'aj.org.objectweb.asm.ClassReader'). Stackmap generation for woven code is required to avoid verify errors on a Java 1.7 or higher runtime
when weaving type org.eclipse.core.resources.IProject
when weaving classes
when weaving
at org.aspectj.weaver.bcel.LazyClassGen.getJavaClassBytesIncludingReweavable(LazyClassGen.java:703)
at org.aspectj.weaver.bcel.BcelWeaver.getClassFilesFor(BcelWeaver.java:1443)
at org.aspectj.weaver.bcel.BcelWeaver.weaveAndNotify(BcelWeaver.java:1405)
at org.aspectj.weaver.bcel.BcelWeaver.weave(BcelWeaver.java:1183)
at org.aspectj.weaver.tools.WeavingAdaptor.getWovenBytes(WeavingAdaptor.java:527)
at org.aspectj.weaver.tools.WeavingAdaptor.weaveClass(WeavingAdaptor.java:363)
at org.eclipse.equinox.weaving.aspectj.loadtime.OSGiWeavingAdaptor.weaveClass(OSGiWeavingAdaptor.java:276)
at org.eclipse.equinox.weaving.aspectj.AspectJWeavingService.preProcess(AspectJWeavingService.java:154)
at org.eclipse.equinox.weaving.adaptors.WeavingAdaptor.weaveClass(WeavingAdaptor.java:238)
at org.eclipse.equinox.weaving.hooks.WeavingHook.processClass(WeavingHook.java:164)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.processClass(ClasspathManager.java:737)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:695)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:641)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:609)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:589)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:568)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:467)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:474)
at org.eclipse.osgi.internal.framework.BundleContextImpl.lambda$2(BundleContextImpl.java:808)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:569)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:802)
... 27 more
Root exception:
when weaving
!ENTRY org.eclipse.osgi 4 0 2021-11-16 15:28:41.551
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (127).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:126)
... 13 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
... 20 more
when weaving
... 27 more
Re: Eclipse will not restart after package installation [message #1848025 is a reply to message #1847980] Wed, 17 November 2021 10:01 Go to previous message
Yes, it looks like something it requires was not compatible with Java 17.
Previous Topic:Unable to download 2020-x R "Eclipse IDE for Enterprise Java Developers"
Next Topic: Eclipse working set concept
Current Time: Sun Jul 20 10:16:46 EDT 2025
Powered by FUDForum. Page generated in 0.09407 seconds
