Using Ecore2Java with dependent models [message #1844203] |
Mon, 06 September 2021 06:28  |
I have a set of models that have inter-model dependencies, that is:
a client EPackage in one Plugin containing EClasses which are subclasses of EClasses residing in another EPackage inthe supplier Plugin.
I want to generate the two plugins using one execution of Ecore2Java, without installing the supplier in the runtime first.
I do not want to duplicate the classes, but use the OSGI manifest and Java package import mechanism.
- Is this possible?
- Is there an example for such execution?
- Where could I find it?
I would believe that this is a fairly basic requirement for CI/CD with models. So I am surprised not to find any examples.
[Updated on: Mon, 06 September 2021 06:29] by Moderator
Re: Using Ecore2Java with dependent models [message #1844400 is a reply to message #1844366] |
Mon, 13 September 2021 01:34  |
Hi Ed,
I know how awful Ant is. Really do. I am not endorsing its design at all. My aim is to use it as a dispatch point to get a wide scope of MDE tools.
The reason I was after Ecore2java is that Epsilon's Eugenia Ant support, which is excellent, is currently intertwined with, you guessed it, the Eclipse workbench. While this gets sorted out, I needed a way to build our four-level model hierarchy. So I thought that like in a car, the on-board tools may be ugly and cumbersome, but must work.
On prior topic: To mitigate the horrific nature of Ant, I have set up a structured development method in our company. During development time, this gives clarity.
We have exploited Tycho's Test Environment in conjunction with AntUnit and the Eclipse Ant Runner dispatch to allow us to test and cover interactions. AntUnit allows us to do wider coverage of the dispatch. And the rest has to be unit tested.
Using the Eclipse infrastructure frees us from dependency hell. The tasks are Eclipse features. You install them by director call on the shell into the builder, then you run your model-driven build. Or you use the tasks in your IDE. Works the same way. Most of those builders are pre-packaged in containers though.
My devs were initially very sceptical of this design. But it works far better then expected.
All the best from Brisbane, JG
[Updated on: Mon, 13 September 2021 01:35] by Moderator
FUDForum. Page generated in 0.06019 seconds
